Electronics RGB Mood Lighting
Discussion in 'Modding' started by dan-ere-07, 8 Jul 2009.
  1. dan-ere-07
    dan-ere-07 New Member
    29 Mar 2007
    Hello,
    I want to add RBG Mood Lighting to my bedroom ceiling.
    A idea of what i mean:
    Lights here:
    The hole size will be 1.2m by 2m so i will need 6.4m of lights.
    What would be the cheapest way of doing it? buying a kit or buying RGB LED strip.
    What controller would be the best? i would like to controll it from my pc and by remote (if possible)
    Thanks
    mvagusta likes this.
  2. mayhem
    mayhem Owner of Mayhems
    12 Sep 2008
  3. dan-ere-07
    29 Mar 2007
    Thanks
    I have found places that sell RGB LED strip in 5m lenghts.
    But then i would need a controller for it.
    do you think that controller would cope with a 7m strip?
  4. mayhem
    12 Sep 2008
    the controller i use is £25.00
    If you what one i can get you one.
    up to 30 meters mate.
    there are more expensive controllers out there costing any ware from £25 to £250 (but alot of them are rip off's)
  5. mayhem
    12 Sep 2008
    i can do up to 5 meter but its not cheap inc controller you looking at about £75.
    Delivery would take about 2 weeks as i only some 30 cm strips left with controllers in stock..
  6. dan-ere-07
    29 Mar 2007
    ive found a 5m reel for £59 and i think they can suply a custom length, so ill see how much a 7m length will be then get a controller seperate.
  7. mayhem
    12 Sep 2008
    well with controller you going to pay more than the price ive just said , have a look around any way and if you interest pm me ...
    the strips normally come in 30 cm / 1 meter / 5 meter / 10 meter / then 100 meter's
    all can but cut to length. But a 10 meter one is not cheap and you don't get the controller with it.
    just been checking sizes this Controller can handle and it cannot handle more than 6 meters. The 30 meter controller is far to expensive.
  8. dan-ere-07
    29 Mar 2007
    They can cope with 7m but they will have a bit of interferance.
    i think i will order 7m (whether 10m, 2x5m or 2m+5m) and see how bad it is.
    Edit:
    I have found an amplifier for it.
    It will add an extra 5m of avalible strip.
    I might get 10m of it then use the amplifier and add more LED's over my room.
