Windows Ripping DVD's for XMBC
Discussion in 'Software' started by Thatguy119, 10 Jan 2010.
  1. Thatguy119
    Thatguy119 Minimodder
    17 Nov 2008
    Basically, I have been ripping all my DVD's over the last month with the plan being to put them on a file server and run them through xmbc on our HTCP in the living room over the network. A bit stupidly, I have only looked at the results of the ripping today, and found instead of one big media file a load of seperate .vob and .iso files that I cannot open in a folder called Video_ts file. As I kinda predicted, after XMBC scanned the HHD it said there were no video files there. What would the best way of converting the files into something it can read? I am not worried about space so compression is not required.
  2. azzybish
    azzybish What's a Dremel?
    23 Apr 2009
    Handbrake SHOULD be able to convert them into some readable files, have a poke around in the settings.
  3. Bumfluff101
    Bumfluff101 Minimodder
    10 Jan 2010
    Just had the same problem, need to check out this handbrake program
  4. Gryphon
    Gryphon What's a Dremel?
    24 Apr 2009
    handbrake will convert the .vob files to mp4, but the .iso files might need re-ripping as they're just disc images.
    When you say 'lots of', do you mean its split the films into 1GB chunks? thats what DVD Shrink 3.2 does by default, and i dont know of a program to re-combine them into one file... handbrake wont.
  5. Lankuzo
    Lankuzo CPC Refugee
    23 Apr 2009
    I think your best bet would be to just copy the films with dvdfab.
  6. Thatguy119
    17 Nov 2008
    handbreak is taking ages to convert the files. Is it the proceccor thats limiting it? (I am on a p4 so I would not be suprised)
  7. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
  8. Thatguy119
    17 Nov 2008
    Im on intigrated graphics so if it uses a card I might be in trouble.
  9. bob
    bob What's a Dremel?
    15 Dec 2009
    Handbrake is multithreaded and maxes out all cores so yeah. When I had a Pentium D it took about 3 hours a film, so a p4 will take ages.
    I'm not sure but i think using x264 takes far longer that xvid/divx, so check what settings are used.
  10. azzybish
    23 Apr 2009
    3 HOURS? THREE? HOURS?
    You seriously need to upgrade your PC. My Q6600 rips a DVD and converts to iPod format in around 15 minutes.
  11. bob
    15 Dec 2009
    "When I had a Pentium D" I said. I too have a q6600 now, which is a great cpu. I haven't converted i ipod before but it would probably take just as long for me. But it definitely takes under an hour for a x264 1.4 gig file with two passes.
  12. Lankuzo
    Lankuzo CPC Refugee
    23 Apr 2009
    if you just download the shark007 codecs they should play. All you need to do is search manually for a film or folder containing films then click stack files. this should let you play the films.
  13. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    XBMC Media centre can read iso files there is a way to tag them in the library somehow (its on the Wiki) not entirely sure on the process however as i use the MKV container
  14. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Is the OP really talking about ISO files or did he mean IFO files - i.e. DVDShrink has just created a load of folders containing a proper DVD structure?
  15. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    What did you rip them with in the first place?
    It will surely be faster to find a way of ripping them into the format you want rather than converting them on a Pentium 4; I would consider a new computer a wise investment if you're going to be doing a lot of this...
  16. Krikkit
    21 Jan 2003
    I'm disappointed no-one has mentioned AutoGK here yet - Handbrake is all well and good but it's no substitute tbh. :D
    dave_salmon likes this.
  17. Lankuzo
    Lankuzo CPC Refugee
    23 Apr 2009
    i dont see why you would need to use any of them as xbmc can read vob files. if you use dvdfab to copy films all you need to do is stack the files in xbmc and they play fine..
  18. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    Get dvd decrypter. Rip to one Ifo file.
    Convert that one file to MKV or other file of your choice. You may need anydvd running in the background to remove encryption on the dvd's.
    As for Auto GK. If you can play MKV and have a fast enough pc, it's a better format than using AVI with Auto GK. I get smaller files when I use RipBot x264 converting to MKV than with Auto GK and avi (with either xvid/divx encoding).
  19. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    Well if compression is not required, and you're concerned about filesystem tidiness, why not just re-rip them to ISO Files? Use DVD Decrypter or DVDFab and just set it to ISO reading mode...
    As mentioned several times, XBMC handles ISO and VOB files no problem.
  20. Thatguy119
    17 Nov 2008
    SOrry, I meant IFO files, there are also some .BUP files, dont know what they are
    This is what the video_TS folder looks like, are you saying XMBC should be able to read this no problem?
    BTW, I am only on a P4 while my i5 is RMA'd
