Displays Rippling effect on new TFT
Discussion in 'Hardware' started by SJH, 22 Sep 2009.
  1. SJH
    SJH Minimodder
    24 Dec 2003
    Just got my new Dell 2209WA monitor delivered today, which is the most awesome monitor I've ever used, but...
    On large areas of dark colour, there is a slight 'rippling' effect (sorry if that's not the most descriptive word, was all I could think of), with bands of a slightly lighter colour moving up and down.
    I'm hoping this is a common complaint and that monitor experts reading this will know what I mean...!
    So what I want to know is, what do I do about this?
  2. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    Install the driver for it, did it come with a CD?
  3. antaresIII
    antaresIII tephigram
    25 Feb 2009
    It really must be the most awesome monitor you've ever used.
    I mean it's Dell!! (if it would be something else...)
    Kyocera likes this.
  4. SJH
    SJH Minimodder
    24 Dec 2003
    Yeah already installed drivers for it.
  5. Akava
    Akava Lurking...
    28 Jul 2007
    If it was only delivered today give it a few days; it could just be a few points when the crystals have... settled as it were.
  6. SJH
    SJH Minimodder
    24 Dec 2003
    But I want it to be perfect now dammit! ;) OK I will take your advice and be patient.
  7. Krikkit
    21 Jan 2003
    Was it cold when you fired it up? It could've gone a bit clumpy if it's been in a cold warehouse then a cold delivery van.
  8. SJH
    SJH Minimodder
    24 Dec 2003
    Not that I can remember. It wasn't opened until about three hours after being delivered anyway.
  9. SJH
    SJH Minimodder
    24 Dec 2003
    Just been doing a bit of experimenting, and I'm not sure how relevant this is but I thought I'd throw it in anyway: this only happens on very dark grey and green backgrounds; never 100% black, or dark red or blue. Is this likely to mean anything?
  10. tripwired
    tripwired Deploying Surprise in 3... 2...1...
    12 Feb 2009
    Some kind of interference perhaps?
    • Try using a different monitor cable, give the VGA a go as well if you have a cable knocking around.
    • Connect to another PC or laptop and see if the problem persists.
  11. SJH
    SJH Minimodder
    24 Dec 2003
    Yeah will give those a try when I get home tonight, thanks. It's currently connected by VGA as that's the only video output my laptop has. My secondary computer has DVI out so will give that a go.
  12. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    I would think it would be because you have it hooked up via VGA - long cables, high resolutions and laptops with sub-standard VGA ports can all cause issues.
    One of my friends 24" screens, on being attached to his laptop via VGA, certainly took a turn for the worse in image quality.
  13. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Yep - It's the VGA cable - I have this with one of my cables.
    Try either a shorter cable, or a higher quality one (don't pay too much over the odds though!)
  14. SJH
    SJH Minimodder
    24 Dec 2003
    Cool stuff, I really hope it's as simple as that :)
    Thanks very much for your input guys. I'll let you know how I get on later tonight.
  15. Krikkit
    21 Jan 2003
    It could be a ground loop problem with the laptop too - they're not uncommon.
  16. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    I have the same problem anfd I use VGA
  17. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Does the laptop have an HDMI out? You could try using an HDMI->DVI cable if so.
  18. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    I have that monitor - No such issue here on both DVI or TV output :/
  19. mrbungle
    20 Sep 2004
    I have similar problems on a VGA only 22" panel.
    Same computer hooked up via dvi doesn't do it so id try to avoid vga if possible...
  20. SJH
    SJH Minimodder
    24 Dec 2003
    Hello again everybody...
    Good news! Managed to get my secondary computer which has DVI out up and running and the problems I described above are non-existent. Now all I need to do is get the thing set up to work full-time and I'll be sorted :)
    Thanks for the input guys and girls, much appreciated.
