Windows Rise of Nations - low disk space for swapping file
Discussion in 'Gaming' started by Moyo2k, 29 Oct 2010.
  1. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Trying to install Rise of Nations on an old XP (SP3) PC, keep getting to about 35% before it says (extracting file game2.cab failed, low disk space for swapping files) I tried increasing the virtual RAm all the way up to 32768MB but it didn't do anything, checked the disk drive, still nothing... it's annoying because I got it fully installed before uninstalling it because it kept crashing to try and reinstall it
    Any ideas?
  2. robots
    robots What's a Dremel?
    27 May 2010
    I found this on tinternet:
    1. Disable any firewall / antivirus software;
    2. Click My Computer / Rightclick the Drive & Choose Properties
    / Run the "Disk Cleanup..." / Next Click the "Tools" Tab and run
    the "Error-Checking" and "Defragmentation" utilities.
    3. Try installing again. Good luck! :)
