Scratch Build – Complete ⭐ ROG Fusion mod
Discussion in 'Project Logs' started by jones-965, 2 Dec 2017.
  1. jones-965
    jones-965 Modding & tuning
    13 Jul 2011
    Hi guys!
    Again new project, in which new support partners helped me. Thanks for the support FSP Group, Bitspower Company and Asus Hungary.
    Specification:
    Asus Rampage V Edition 10
    i7 6850K
    HyperX Fury 4*4Gb 3200Mhz
    HYperX Predator 240Gb M.2 ssd
    Asus GTX 980Ti Matrix Platinum sli
    FSP Hydro PTM+ 1200W
    Cooling:
    Bitspower RVE10 monoblock
    Bitspower GTX980Ti gpu block
    Bitspower RAM module set
    Bitspower HD fittings and HD tubing
    Bitspower Water tank Z-multi 250
    Bitspower D5 MCP655 mod kit
    Bitspower Leviathan slim 480
    [​IMG] [​IMG] [​IMG]
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. jones-965
    13 Jul 2011
    The double side panel.
  3. Cheapskate
    13 May 2007
    Looks promising.
    FYI: I found out you can use plumber's PVC glue on the foam core material. Gluing it to a sheet of glass overnight fills the cut edges really nicely too.
  4. jones-965
    13 Jul 2011
    Thanks for the information. :)
  5. jones-965
    13 Jul 2011
    The watercooling install.
  6. jones-965
    13 Jul 2011
    The project has been completed
    CSZModified likes this.
