Blogs Router reboot
Discussion in 'Article Discussion' started by brumgrunt, 14 Aug 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    I feel your pain. I've set up the PC's in my house with statics ips and port forwarded them for things like torrents and mmos. While the router my isp gave me will often stay up for a couple months without needing to be reset and doesn't fall over due to gaming, its wireless function is pretty pathetic. Go a couple rooms away and it becomes utterly rubbish. Sadly I can't afford to spend upwards of £80 on a good one.
  3. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    IpCop and an e-Machines Pentium 2 last time I checked it had an uptime in the 450+ days and that was only because I was out the country for a month. Its got to the point where I'm scared to turn it off in case it never comes back up.
    My cable modem on the other hand has taken to crashing at alarming intervals, I've had to dig it out of its nice hiding place and leave it some where more accessible so I can hit it with flint tools.
  4. Harlequin
    Harlequin Modder
    4 Jun 2004
    my own netgear DG834GT is begining to show signs of not being loved anymore..... was faithfully reliable but starting to not be (it is 6 years old now)
  5. =DJ=
    =DJ= Torturing x86 since '86
    18 May 2010
    Aside from the occasional silver-bullet firmware update I've found most flaky routers are made a lot more reliable by simply turning off the built in WiFi, and using a proper separate AP anyway.
    One Thomson router I had would freeze within a couple of hours if an iPhone was connected to it, but never needed power cycling again once the WiFi was turned off... (ADSL up time was always around a month)
    With perfectly adequate APs available for under £20 it's not an expensive experiment to try if you're suffering reliability issues. :)
  6. wyx087
    wyx087 Multimodder
    15 Aug 2007
    DD-WRT is the answer :D
    got myself a high end Linksys DSL router for DD-WRT, then using ISP provided router as modem. never had any problem or issues with configuration or freezing.
  7. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    I'm using the wireless router supplied by my ISP, unfortunately it's locked down, pre-configured and about as reliable as a chocolate teapot filled with luke-warm water - it'll work but how long before it melts?
    I've got another router (which I've not used) but as I don't have any of the settings (as the router was pre-configured) I can't use it.
  8. yuusou
    yuusou Multimodder
    5 Nov 2006
    My Thomson 784 (no N for wireless) has been working fine for the last two years. Only thing I feel it lacks are N (obviously), Gigabit ports and no NTFS support on the USB port. Other than that, it's uptime = 47 days, 12:40:25 (at the time I ran the command). Of course I've done some tinkering on it, but that's what I do during my day job, so it's trivial.
  9. Valinor
    Valinor What's a Dremel?
    30 Oct 2010
    Actually, I'm using a BT Home Hub (3, I think) and that openreach fibre box thingy, and I've only had a couple of issues (connection dropping) in the year-and-a-bit in which we've had it.
    As I said, it's hardly been perfect, but it's still been surprisingly good (I also have an old Home Hub, which decides that for the first week after being plugged in it'll drop the connection every minute. After that it's mostly fine, but annoying when that week happens to be half-term week, for which I was at home almost all the time).
  10. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    well at least BT have made it easy to replace the BThub3 when on FTTC, the bthub3 N and auto channel select really does not work well at all its still broken for the most part
    like what BT do when they remotely connect to it you set the device to B/G mode (no N) and pick an channel like 1,6 or 11 as they are none overlapping channels and that fix's basic all its issues with devices randomly not working after 1 to 24hrs
    DD-WRT on my edimax Gigabit N router been working fine for an years (the 40 N mode does not work but 20 N does)
  11. Jaybles
    Jaybles Minimodder
    12 Feb 2011
    All my routers used to break within a year, often half a year. I was then given a BT Business Hub made by 2Wire. This thing is awesome. Hasn't fallen over once in the 2 years I've had it. The only fault is a dodgy power cable that when knocked has a chance to turn off but that only happens when fiddling with the wires and has been there since I got it.
    Edit: The problem with DDWRT is that AFAIK they don't support ADSL modem routers.
  12. PCBuilderSven
    PCBuilderSven Minimodder
    3 Oct 2010
    My Linksys router works without problem, haven't had to reboot it ever so it's been running for over two years now.
  13. digitaldunc
    digitaldunc What's a Dremel?
    4 Oct 2010
    I used IPcop up until 2005 with an ancient pentium with an ISA 56K modem and it was bulletproof. Automagically maintained my pitiful connection 24/7, relatives were trying to get through to the landline for months :D
    Used smoothwall for a couple of years as well when broadband finally dawned here which was pretty good until the modem in the box died -- it was pretty solid apart from that.
    At the moment I'm using a Netgear DG834G that's a few years old -- pretty basic feature set but does an adequate job, albeit I'm the only one that uses it generally.
    I'd suggest you give a firewall distro a go if you've got an old mini itx board or old laptop kicking about, though depending on the hardware you might be talking excessive power usage for the end goal.
    I've noticed a trend with recent combi router/switch/APs that limits the speed of the wireless connection and only allows higher/full speeds on the more expensive models -- I suspect this is artificially rate limited via firmware rather than a hardware limitation. I'd concur in suspecting that the vast majority of these cereal boxes the ISP supplies or you buy in PC world are crap.
    How about a roundup of quality routers at some point? Not the most glamorous tech but something a lot of us would appreciate, I think.
  14. faugusztin
    11 Aug 2008
    I gave up on routers. I have a 100/8 Mbit internet and even such model as Linksys E2000 has problem routing it (with E2000 i had ~90/5MBit, with a router from my server i have 105/7Mbit).
    Routers often have too low performance as well for a demanding user. You can easily slow down the router to halt just by starting some application which opens lots of connections (torrents for example) where the usual cap of 500 max connections vanishes and you are left with unstable connectivity - simply because the router cannot open more connections.
  15. Krikkit
    21 Jan 2003
    I've experienced the same problems with provided routers (a particularly awful BT home hub springs to mind), but the last two have been awesome.
    My DG834GT was retired because it couldn't cope with our wireless printer, to be replaced with a TP-link which is even better. 75 days uptime at home now and still going strong.
  16. law99
    law99 Custom User Title
    24 Sep 2009
    Billion 7800n worked a treat for me during a 6 month stint at my parents. Never flaked out... But this was streaming video mainly.
  17. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    Sorry, but no. My Buffalo AirStation Infiniti WZR-HP-G450H came factory configured with DD-WRT firmware, and it has stupidly low power output to antennas resulting in poor signal strenght and tends to freeze completely couple of times a day. Switching to Buffalo's own firmware makes it somewhat more useable, albeit only barely. Not a great showing from +100EUR wireless device.
    I'm going to try running it with OpenWRT one of these days.
  18. steveo_mcg
    26 May 2005
    Power usage will be higher but even my p2 only draws 25w and the difference in cost between an epia and a good router buys a lot of electricity.
  19. Floyd
    Floyd Wire Twister
    4 Dec 2008
    Never had to reboot my Netgear router.
    Just plugged in my settings and away it goes.
  20. wyx087
    wyx087 Multimodder
    15 Aug 2007
    factory configured is your problem. try install a micro version of proper DD-WRT it should work better.
    the fact it barely worked with stock Buffalo firmware shows there's something wrong with the router.
    also, why would it come factory configured with DD-WRT yet there's a stock Buffalo firmware? shouldn't stock be same as factory configured?
    i've been using multiple Linksys router with DD-WRT for over 4 years now, never had any problem. always used the ISP router as a modem.
Tags: Add Tags
