News Rumour: Intel discovers Sandy Bridge E bug
Discussion in 'Article Discussion' started by arcticstoat, 4 Oct 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Again? Intel's quality control really has been slipping for the last few releases. At least it hasn't been released yet, unlike last time.
  3. javaman
    javaman May irritate Eyes
    10 May 2009
    Intel are so far ahead of the competition that even delaying these processors wouldn't be a big deal. Hats off the developed a c2 stepping so quickly tho.
  4. pingu666
    pingu666 What's a Dremel?
    24 May 2010
    the quality control was fine in this case, caught the issue before release...
  5. PlayedStation
    PlayedStation Possessed like an apostrophe
    21 Oct 2010
    The cynic in me says this increase in manufacturing costs is marketing hyperbole to justify a price hike
  6. Hakuren
    Hakuren What's a Dremel?
    17 Aug 2010
    It is massive bug not a little one.
    X79 is targeted at server/workstation market where VT-d is absolutely crucial. Right now running my X58 with VT-d enabled and frankly I can't imagine using PC without it as long as I need legacy software/test stuff with different OSes using VM. If VT-d is screwed in the first batch of the chips then the only solution (apart from scraping) for Intel is to ship those CPUs into OEM market where VT-d is not important.
    " which isn’t likely to be much of a problem for home users (breathe a large sigh of relief)"
    It is purely nonsensical statement considering how many people using VT-d at home. Some because work require it, some because they need something so trivial like XP Mode on W7.
    With every news X79 looks less and less worthwhile investment. If someone need more space for storage then spend money on new RAID card, if you need proper SAS support - spend that money on RAID card. If you need dual CPU and lots of RAM then there is plethora of Xenon 1366 boards around. There is absolutely no need to blow hard earned cash on X79 for what 10-15% better performance (even when they fix VT-d). I said in 2008 that S1366 will be new S775. Looks like a fact ATM. There is plenty of life left in X58.
  7. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    I do care about virtualization ... take your time Intel :thumb:
  8. l3v1ck
    23 Apr 2009
    Well, sort of.
    They might not have to do a recall if people/companies know what they're buying, but if the replacement chips aren't available until after launch, then quality control wasn't good enough as they didn't pick it up in time.
  9. azazel1024
    azazel1024 What's a Dremel?
    3 Jun 2010
    There is plenty of life left in a lot of older intel chipsets and processors. Most generations only see a 10-15% improvement, so its not like we are seeing a world of change moving up. However, it is an improvement, and if you need it, great.
    The top end chipsets and processors from Intel are always expensive. Going from X58 to X79 doesn't look like it is going to be THAT much more expensive. An extra $14-20 for the board because of a more expensive chipset isn't that big a deal when you are talking a 4-8% increase in MoBo/CPU combined price. Processor cost looks like it is going to be roughly where X58 was when it came out. So you are looking at a small increase in cost, for generally a 10-15% improvement in processor power (with a few cases where they is much, much more improvement). Doesn't sound like a bad deal if you are upgrading from an even older chipset and processor. If you are already on X58, it doesn't sound like it makes a whole lot of sense, but it rarely does to move just one generation forward unless you HAVE to have the extra increment in performance.
  10. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    I just read through vt-d from Intels web pages .. and am still non the wiser to what its actually for
  11. BlackRaven
    BlackRaven Freaking printers!
    20 Feb 2010
    That is definitely not a small problem. How do you think most people test new apps and do their coursework for certifications at home...
  12. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    it's meant for immensely improving virtualization. the amd-v instruction set is pretty much the exact same thing. try running something like virtualbox with and without vt-d/amd-v enabled and you'll see a day and night difference in performance.
  13. Bob1234
    Bob1234 What's a Dremel?
    30 Jul 2008
    It provides direct access to hardware for virtualised environments.
    Think VMWares ESXi and Microsofts Hyper-V, where you virtualise everything, and VT-d allows the virtual machines to directly access parts of the host PCs hardware.
  14. Anneon
    Anneon What's a Dremel?
    30 Sep 2010
    Hmmm.. I was holding out upgrading my old Q6700 machine for the sandy bridge-e. I guess i will buy up some old stock 2500k now.
    oh wait.. yea my q6700 still kicks ass at 3.7ghz
  15. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Can anyone tell me what the difference between VT-x and VT-d is?
  16. MjFrosty
    MjFrosty Minimodder
    3 Aug 2011
    That is definitely NOT just a small problem. It's an inconvenience to home users as well, and I'd like to think it worked on C1 when I've just spent close to £800 on a CPU. Somebody needs a thump and a P45 their way.
    I like wasting cash on new platforms, however the closer x79 comes to it's release the more and more it seems it's a complete waste of time, and an interim to the changes they will make in early 2012.
    Just because you've no competition in the market sector is not an excuse for sloppy and quite frankly half arsed hardware - which from what I'm gathering is purely to meet the needs of the corporate system builders.
  17. Blarte
    15 Jul 2008
    ah ha Laymans terms ... gotchya
  18. Blarte
    15 Jul 2008
    20 other letters?
  19. Action_Parsnip
    Action_Parsnip What's a Dremel?
    3 Apr 2009
    This. x79 looks nowhere near as good as x58 was. Where is the value prospect ala i7 920??
  20. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Get it together Intel, you've not shown me anything that would make me leave my beloved Lynnfield. Still running like a boss today. 2.8 to 4.4 works for me.
Tags: Add Tags
