Scratch Build – In Progress RX8-CarPooter - July 27th 2009 - Software: WIP. Hardware: Nearly done.
Discussion in 'Project Logs' started by DarkLord7854, 23 Dec 2008.
  1. stuartwood89
    20 Aug 2008
    If this was my car, I'd want it to look as clean as possible, so everything would be powered from the battery and not the cigarette lighter. For some reason I just hate seeing stuff plugged into those.
    mvagusta likes this.
  2. SeT
    SeT What's a Dremel?
    7 Oct 2003
    I know you want to keep it stock as possible and clean but would you consider splicing into the line to the lighter? Shouldn't be difficult and easy enough to undo plus you keep the clean look of not just plugging something in there.
  3. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    I've found a neat, clean, way of running the wire, will do it tonight after work :)
    The only thing I'll have to power by cigarette lighter is the screen, but it's only temporary, next week I'll strip apart the plug for it and see if I can wire it up cleanly.
    I'll be splicing into it eventually, but for the PSU I'd much rather have a direct line to the battery, for the positive terminal anyways. The negative has to go onto the cigarette lighter since it only gets power when ignition is on, that way the PSU will turn on/on with engine.
  4. tominated
    tominated What's a Dremel?
    28 May 2008
    what i would do is cut off the cigarette lighter plug off the screen and replace it with a molex plug. it's easy and it doesn't involve messing with the car wiring as much. I did it for my car pc (WIP) screen
  5. DarkLord7854
    22 Jun 2005
    Hmm.. We'll see, I haven't fully decided what I wanna do with the screen.
    I finally managed to get a cable through, I got pissed off, took my soldering iron, heated it up, and just rammed it into the rubber wire harness cover and it burned a hole through it and most of the silicone, no wires were damaged, I slid mine through and sealed it with silicone.
    I'm now kicking myself because I dropped the battery bolt connector into the engine bay and I can't find it.. :sigh:
  6. jodah175
    jodah175 Wannabe Modder
    26 Oct 2006
    haha, lost to the abyss.
    I Didn't realize this was a lease, but like others have said, if you want it clean, splice it into an inconspicuous spot, maybe make a small distribution block under the center console?
  7. Shuriken
    Shuriken same christmas AV for a whole year
    1 Jan 2003
    I think I speak for everyone when I say:
    Moar pics pls, kthxby :p
    (ew, typing like that make me feel dirty)
  8. DarkLord7854
    22 Jun 2005
    I actually didn't take any pics of the installation process of the wires >.>
    On the bright side, I had to give up last night after running the battery wire and will need to remove the panels again whenever I pick the project back up next week, so I'll post pictures whenever I get back from my trip this weekend :)
    Word of advice.. don't hold the cable you just connected to the battery in one hand, and touch the car's frame with the other hand.. I won't be making that mistake again anytime soon o.o
  9. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    Tingly!
  10. murtoz
    murtoz Busy procrastinating
    9 Apr 2008
    +1, you typing like that even made ME feel dirty! ;)
    I agree with the sentiment though: moar pics!
    (oh noes! it's contayjus!!!)
  11. DarkLord7854
    22 Jun 2005
    Project has been put on hold, my transmission is shot and I need to take it to the dealership, so I won't be working on this until they fix RX8 or give me a new one.
  12. SeT
    7 Oct 2003
    ouch. suck. hope they replace it as defect and don't say you were hard on it and launching hard.
  13. DarkLord7854
    22 Jun 2005
    If they replace it, it'll be my second transmission within 10,000miles. They had to replace the first tranny at 300miles because they sold it to me with a destroyed 3rd and 6th gear syncro (naturally tried to tell me I was at fault).
    I'll be removing all wiring and stuff so they don't find some stupid excuse to blame me, I can totally see them say that because I added a wire to the battery I potentially damaged the car.. :rolleyes:
    Dealerships are pricks. :p
  14. stuartwood89
    20 Aug 2008
    I can't see what this has to do with the transmission, but you're probably right in taking your rig out.
  15. DarkLord7854
    22 Jun 2005
    Ok well I have the car back now, it's all good.
    I'll be putting everything back in tomorrow, except for the cameras, I've been trying to find 2 very good day/nigh security cameras with auto-iris to be able to capture usable video while driving.
    I did a test with the webcams and it was pretty crap at quality, and the angle was very narrow.
    Expect updates soon :D
    Ninja-Edit:
    This is one of the cams I'm looking at:
    http://www.at-fairfax.com/P1169-SecoLarm-EV133CDWAVQ.htm
  16. jhanlon303
    7 Sep 2006
    Yippee you're back.
    I like this thread. Put it back and I'm watching.
    john
  17. twentynine
    twentynine Can never win...
    6 Jun 2008
    Same here. I love this type of thing!
  18. DarkLord7854
    22 Jun 2005
    Alrighty, major update! So yesterday I drove to my friend's house and we got to work on tearing the car apart and wiring everything up, putting movo in, etc.
    I had to buy a VGA and USB extension cord and got them a bit too long.. but w/e, better have extra than too little.
    On to the pics!
    Backseats:
    Hi-res: http://tech-burrow.com/bittech/DSC00886.jpg
    Hi-res: http://tech-burrow.com/bittech/DSC00890.jpg
    Centerconsole covers:
    Hi-res: http://tech-burrow.com/bittech/DSC00887.jpg
    Hi-res: http://tech-burrow.com/bittech/DSC00888.jpg
    Battery connection cable:
    Hi-res: http://tech-burrow.com/bittech/DSC00889.jpg
    Rear speaker covers:
    Hi-res: http://tech-burrow.com/bittech/DSC00891.jpg
    I wasn't kidding when I said we tore the car apart, backseats:
    Hi-res: http://tech-burrow.com/bittech/DSC00892.jpg
    You can see the trunk and stuff here:
    Hi-res: http://tech-burrow.com/bittech/DSC00893.jpg
    Front, that pieces sitting near the shifter is the front cigarette lighter, I tapped into it for the flipped battery connection:
    Hi-res: http://tech-burrow.com/bittech/DSC00894.jpg
    Chaotic view of the front:
    Hi-res: http://tech-burrow.com/bittech/DSC00895.jpg
    View of trunk, you can see my laptop:
    Hi-res: http://tech-burrow.com/bittech/DSC00896.jpg
    All wires got routed like this, will get more pics of wires routed later:
    Hi-res: http://tech-burrow.com/bittech/DSC00897.jpg
    Hi-res: http://tech-burrow.com/bittech/DSC00901.jpg
    Me, random:
    Hi-res: http://tech-burrow.com/bittech/DSC00898.jpg
    First re-route decision:
    Hi-res: http://tech-burrow.com/bittech/DSC00899.jpg
    Overview of first re-route decision:
    Hi-res: http://tech-burrow.com/bittech/DSC00900.jpg
    Motherboard:
    Hi-res: http://tech-burrow.com/bittech/DSC00902.jpg
    That's all I got for you guys right now, but trust me, there's a LOT more coming today/tonight because we're going to buy a 3.5mm audio cable and then putting everything back together and calling it done (until I get the dash cameras).
    (these are mostly teaser pics :p)
  19. DarkLord7854
    22 Jun 2005
    Actually, I lied, I have more pics for you guys :p
    Sorry for blurryness, motherboard mounted:
    Hi-res: http://tech-burrow.com/bittech/DSC00903.jpg
    PSU, not mounted yet:
    Hi-res: http://tech-burrow.com/bittech/DSC00904.jpg
    Front view of connected power:
    Hi-res: http://tech-burrow.com/bittech/DSC00905.jpg
    Wires routed:
    Hi-res: http://tech-burrow.com/bittech/DSC00906.jpg
    Final wire route:
    Hi-res: http://tech-burrow.com/bittech/DSC00907.jpg
    Close-up of cigarette lighter splice:
    Hi-res: http://tech-burrow.com/bittech/DSC00908.jpg
    View of rear speakers and amp:
    Hi-res: http://tech-burrow.com/bittech/DSC00909.jpg
    View of wires:
    [imghttp://tech-burrow.com/bittech/DSC00910small.jpg[/img]
    Hi-res: http://tech-burrow.com/bittech/DSC00910.jpg
    View of mobo plus wires plus SSD and stuff:
    Hi-res: http://tech-burrow.com/bittech/DSC00911.jpg
    More updates to come!
  20. DarkLord7854
    22 Jun 2005
    Ok so, I'll have pics of what it now looks like with all the panels put back together, there's still a lot to do though.
    The current setup requires that I plug the screen into the cigarette lighter, so I have to have that panel open. I'll be taking it back apart and splicing the screen power into it directly and running the wire for it like the screen VGA cable, which, when I don't have the screen connected, I easily stuff under the dash.
    After that I also need to acquire some sort of clamp to mount the screen, and finally I need to mount the PSU and SSD onto the ceiling of my trunk and/or devise some kinda of box for it all.
