News SandForce unveils SF-2000 SSD controller
Discussion in 'Article Discussion' started by Claave, 8 Oct 2010.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. Jux_Zeil
    Jux_Zeil What's a Dremel?
    30 Apr 2009
    Looks good as a commercially aimed product but I have to say that after seeing some of the other PCIE X16 SSD cards up and coming, it looks a little slow. One I have seen in the RTM stage is writing at over 1000MB/s. *DROOL*
  3. Makaveli
    Makaveli What's a Dremel?
    25 Nov 2009
    When I actually see a real product review of the consumer version than I can pass judgement.
    There are known issues with the performance of these drivers once there is data they cannot compress and i'm not one to wet my pants over marketing!
  4. AshT
    AshT Custom User Title
    9 Jul 2009
    So, the speed difference between the Intel X25 SSD on 3GB/s SATA and then on 6GB/s SATA will make interesting reading ... or not?
  5. WildThing
    WildThing Minimodder
    26 Jul 2007
  6. Makaveli
    25 Nov 2009
    If you are asking if there will be a performance boost that is a yes, however intel won't be releasing their own chipsets with a native 6GB's SATA yet, so the only current choice are boards with the marvel external controllers which have shown to be lacking in performance as intel current 3GB's SATA connection will often equal it or beat it in real world work loads. Yes the marvel will look good in benchmarks but unless all you do is run sisoft all day that doesn't really hold any water.
    Intel G3 drives are said to be 3GB SATA only and the reason I think they choose this is because the market needs Larger and cheapers SSD's not more performance right now.
    Most consumers will not be able to tell the difference between an SSD that does 250/200 read and writes over one that does 500/500 and i'm referring to desktop work loads not a server which will have different requirements and demands.
  7. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    It'll all come down to money... again. If they can perform like they're claiming they do AND they're considerably cheaper than PCI-E SSD cards they'll be in for a winner. If not... nobody knows.
  8. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Well, they're bringing SATA 6Gbps support with Sandy Bridge, so it shouldn't be a problem when the new SF-2000 drives come out.
    Damn, my Indilinx-based Crucial SSD is getting a bit long in the tooth now. Still very happy with it though. :)
  9. roblikesbeer
    roblikesbeer Bindi's sex slave.
    23 Apr 2009
    Cor, the Storage Networking World Exhibition sounds like a real swell day out!
  10. robots
    robots What's a Dremel?
    27 May 2010
    and a great place to pick up hot girls who just want to party.
  11. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    It hasn't taken Sandforce long to produce another controller, so why are Indilinx taking so long to get a new controller on the market. It seems like ages since their last effort. Since that's all they do, they really need to catch up or they won't survive for long.
  12. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    Hm, might be moving the SSD in this rig to the lan rig, then putting one of these bad boys in the main rig.
  13. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    It's nice to see the numbers, but what I really want is any decent SSD that offers 256GB of storage for a dirt cheap price.
    Still stuck with my hard drive at the mo and not a lot of spare cash.
    I am sure a lot of people are in the same boat, and for me dropping prices is more exciting than top level performance.
  14. spazmochad
    spazmochad Minimodder
    21 Aug 2006
    Nothing which can't be achieved with a couple of vertex 2's in RAID.
  15. perplekks45
    9 May 2004
    Sure, but what if this thing is cheaper than two Vertex 2?
  16. ryall
    ryall What's a Dremel?
    21 Mar 2007
    And what if you like TRIM?
  17. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    sf-1200 works quite well with out TRIM it seems{RAID for e.g.} (the GC works very well page 7 below), you asked me if you should RAID'ed an bit ago i would of sayed your flat stupid as you would end up with the speed of less then 1 ssd or worse in some cases (ok not in that way but norm RAID makes Write latency's go up when cells need to be erased but the GC on the sf-1200 seems to work very well) but again real would use you not notice the difference unless you was using server loads, as to i still stick to buy one SSD the size you need (256GB should do :) + an 1-2TB hdd)
    http://www.anandtech.com/print/3949 (drives uses RAID setup on each half of the card like raid 0+0)
    sf-2000 should be no different if not better
  18. spazmochad
    21 Aug 2006
    They have inbuilt routines which perform maintenance when the PC is idle so TRIM is not actually essential. I don't actually write a great deal to my SSDs either as my desktop, documents and non essential apps and games are all on a hard disk.
  19. leexgx
    28 Jun 2006
    does depend on the SSD some do it better then others with GC (samsung been the worst maybe JMicron as well)
Tags: Add Tags
