Memory Sandy Bridge Memory
Discussion in 'Hardware' started by Erm..., 11 Mar 2011.
  1. Erm...
    Erm... Witty Title.
    27 Jan 2011
    What would you say is the best memory for Sandy Bridge ?
    There are numerous kits out there, here's a few a picked out from the bunch:
    Clicky 1
    Clicky 2
    Are these good kits ? Would you see a performance difference between more expensive kits ? Are there any others ?
    Go ahead ! :naughty:
  2. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
    Cheapest i have the vengence stuff and had to remove the heat spreaders. Both awill perform almost identically.
  3. RedCasino
    RedCasino What's a Dremel?
    19 Dec 2010
    Either is fine, to be honest the first one (the slightly cheaper one) is probably good enough, there really isn't much of a difference, and you are saving about £3 which you can go buy a nice meal for yourself when your new RAM arrives and celebrate the new addition to your system. :)
