So im looking into building a Sandy Bridge Rig within the next week and im having troubles finding a motherboard. THe build i planned is based around a 2500k and would like to overclock abit not extreme. It will probally have 8gbs of ram in the end but to start it will only have 4. The only board i can find that is micro ATX and has a P67 is the ASUS P8P67-M PRO. http://www.newegg.com/Product/Product.aspx?Item=N82E16813131691 Im going with Micro ATX for portablility, i will have to transport the PC periodically. Does anyone know if any other boards are coming to the market soon or should i just get this one. Also is the Intel board overlockable or is it the normal Intel affair. Im using this as a rending rig for Rhino (Vray) and Revit for school. I wont be editing 3D files on it so the Graphics card is going to be a 4650 Temporarily. Thank you,
intel DP67DE and ASUS P8P67-M have a P67-chipset in µATX aswell. But there's nothing wrong with the ASUS P8P67-M Pro.
I am looking out for a mATX P67 board as well and have only found the two jrs77 mentioned. Hopefully Asus will make a P67 GENE soon.
