Sata HDD - very quick and maybe dumb question
Discussion in 'Hardware' started by richtea78, 27 Mar 2004.
  1. richtea78
    richtea78 Guest
    I recently started looking into building my own computer for the first time and had some help from people on here picking the system. Im trying to build it as quiet as possible hence the Tagen Power supply and the Lian Li 6070 case but air cooled as Im scared of water cooling :blush:
    So far I have the case and the motherboard - a DFI LAN Party Pro 875B Intel P4 Motherboard and am now looking for the HD. The mobo has support for 2 SATA drives and Ive seen lots of reviews saying how they are much quieter than similar IDE drives. My question is this
    Would it be possible to use 2 Seagate SERIAL SATA Barracuda 7200.7 80Gb drives without using an IDE drive at all or would I need an IDE drive in the system as well? I think it would be ok but would like some confirmation from someone who knows a bit more about it than me
    Thanks in advance for you help
    Chris
  2. Monster63385
    Monster63385 What's a Dremel?
    18 Mar 2004
    Houston, TX
    Yea its possible, you just need to install the drivers for the SATA controller when it says press F6. I run a WD 36GB raptor 10k rpm hard drive and thats all. for killer speed you might want to consider a pair of 74 GB raptors in a raid 0 arrray, expensive but well worth it.
  3. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    In front of my monitor
    Actually, Monster's got it wrong. You don't need to install any drivers because the SATA controller is on the southbridge as opposed to being on a seperate controller. This is all transperant to the OS.
  4. TMM
    TMM Modder
    12 Jan 2004
    nah you still do, otherwise the setup won't detect it when you install the OS.. even if its onboard...
  5. Will
    Will Beware the judderman...
    16 Jun 2001
    Aberystwyth, boyo.
    Thats what I thought too, but rtt tells me otherwise :)
    Basically I think with the S-ATA controller built into the ICH5R Southbridge on Intels i865/875 chip, you don't need to install the drivers using the old 'press F6 at the install menu' method, as it somehow tricks Windows into seeing them without drivers so you can set up with them. Remember this only applies to the S-ATA controller built into the southbridge, not the additional silicon image S-ATA controller a lot of Intel boards have as well as the ICH5R ones.
  6. richtea78
    richtea78 Guest
    Will - whats RTT?
    Just to confirm then as the mobo has the ICH5R southbridge I should be ok to connect the SATAs up without an IDE? I am installing a floppy into the system anyway as I like them and still use it so if I do have to install drivers that should be possible
    Thanks everyone for your help
    Chris
  7. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    UK
    You will learn..
    He's the forum Admin
  8. richtea78
    richtea78 Guest
    Thanks - I thought it was something like Read The Thread :duh:
  9. mushky
    mushky gimme snails
    24 Mar 2003
    cambs uk
    This is RTT. Fear him.
    If you want quiet, steer well clear of raptors. I cant see how a SATA drive can be quiter than an exact same IDE one, as these are just the interfaces. The actual drive moving parts are the same. Someone please correct me if I'm wrong..
    I thikn you want to look out for drives with fluid bearings. I could be wrong..
  10. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    Planet Mok
    if you want quiet get the hdds you suggested...you wont hear them...
    i run two 120gig ones and they cant be heard...
  11. aaronrkelly
    aaronrkelly What's a Dremel?
    1 Jan 2004
    Iowa
    I have an Intel D865GLC mobo and there is NO need to install drivers - the SATA just works....there is NO drivers to install.....other chips may require them.
    I also run a Raptor. FAST, REALLY FAST.....but definitely NOT quiet. Definite clicking noises can be heard over my PSU and my 4 case fans.
    I dont see how any SATA drive would be quieter than a PATA one. Most SATA drivers are pretty much PATA drives with a chip to do the conversion built on the hard drive controller - the mechanics cant be much, if any, different.
  12. Kermet
    Kermet [custom title]
    18 Feb 2003
    Edinburgh
    I have 2 120GB SATA Seagates, nice and quiet...
  13. TMM
    TMM Modder
    12 Jan 2004
    it will work if you add a sata hdd and windows is installed to something else. but if you ONLY have sata, and you wnat to install windows and all the hdds are blank, you need a floppy ;)
  14. aaronrkelly
    1 Jan 2004
    Iowa
    No man, let me say this again - NO NEED FOR DRIVER....EVER!!! The ICH5 chipset supports SATA natively - it basically shows up as IDE channel 3 and 4. My Raptor is my BOOT drive. I put in Windows XP CD and just installed. NO DRIVERS NEEDED.
    NONE
    NADA
    ZERO
    NO DRIVERS needed if SATA support is built into the chipset. If its a chip on the motherboard that is linked to the PCI bus then yes - you will need a driver. Read more about motherboards, trust me.......my ABIT IS7-E is like this also.
  15. Pookeyhead
    30 Jan 2004
    Blackpool, UK. Cheesecake!
    Where did this myth begin? I have 2x 80Gb, and 2x 160Gb Seagate Barracuda SATA drives. You can hear them. At idle they're silent, yes, but head activity is actually louder then my old drives, which were 7200rpm Deskstars. I've also owned Maxtor drives, and they were quieter as well. The Seagate drives are silent when just idling, yes, but as idle noise on all but the noisiest drives are hidden below other system noises usually (unless you run a totally water or passive cooled system), who cares? Head activity noise is what gets intrusive, and all 4 of my Barracudas are louder than the Maxtor and Deskstar equivalents.
    I'm not saying they're LOUD... as they're still very quiet, but this moniker of "silent" they've earned themselves is not deserved.
    Still the best drives you can get tho, as they are quiet, and they are fast... just not silent.
  16. Kermet
    18 Feb 2003
    Edinburgh
    aaronrkelly is right, no drivers needed for the ICH5...
    As for the Seagates, they are not silent when accessing but are pretty damn quiet, the quietest make I've ever had anyway. Though not quite as quiet as the IV series (have had a 120GB V series and 120GB IV series side by side).
  17. felix the cat
    11 Jan 2002
    Planet Mok
    hmm...well i guess you must either be really unlucky, or me really lucky...
    after going through ibm deathstar 75,60 and 120gxp, wd normal, wd se, and maxtor dm9, seagate barracuda II, III, IV, V and now the sata version i still think they are the quietest drives compared to all others in all situations...
    guess that just must be me then...
  18. chucky
    chucky What's a Dremel?
    24 Mar 2004
    northern ireland
    does the asus a7n8x deluxe require a driver?
  19. felix the cat
    11 Jan 2002
    Planet Mok
    yep...but its really easy to install, so no worries!
  20. Michael10642
    Michael10642 What's a Dremel?
    3 Mar 2004
    United Kingdom
    Acoustic management can make head activity quieter, but seach times will almost double.
