Electronics Scart > VGA
Discussion in 'Modding' started by Slink, 20 Dec 2004.
  1. Slink
    Slink B7
    7 Oct 2001
    Middlesbrough - UK
    Dont want to pay shedloads for a simple cable I know one of you lot can make
    Anyone have a diagram of the wireing that even a n00b like me can understand?
    I want to run my Gamecube on my monitor, so I need a scart to attach to my monitor,
    Diagrams if you please, or somewhere to pick up a cable for cheap
  2. infernis
    infernis What's a Dremel?
    5 Jan 2003
  3. Slink
    Slink B7
    7 Oct 2001
    Middlesbrough - UK
    Do you think you could find me an english walk through as my german aint to hot.
    Thansk dude, but that looks like what im after!
  4. Slink
    Slink B7
    7 Oct 2001
    Middlesbrough - UK
    LEt me get my head around this,
    If I follow that diagram, I shoul dbe up and working?
    When it shows two pins on one plug going into one cable, then into two pins on the other plug, this may sound stupid, how would I go about that?, just solder the two pins to one wire, then the same at other end?
  5. infernis
    5 Jan 2003
    Connect
    Pin 15 SCART to pin 1 VGA (Red signal)
    Pin 11 SCART to pin 2 VGA (Green signal)
    Pin 7 SCART to pin 3 VGA (Blue signal)
    Pin 13 SCART to pin 6 VGA (Red ground)
    Pin 9 SCART to pin 7 VGA (Green ground)
    Pin 5 SCART to pin 8 VGA (Blue ground)
    Pin 7 SCART to pin 10 VGA (Horizontal/vertical sync ground)
    Pin 20 SCART to pin 13 VGA (Horizontal/vertical sync)
    Pin 21 SCART to chassis (Chassis ground)
  6. roll1
    roll1 What's a Dremel?
    21 Sep 2004
    uk
    If you want the direct route you can buy a scart to VGA lead from Halfords for £80 but never heard of anyone doing this,plus it must be a suitable TFT monitor.
    Best way is to use a scart to s-vhs adaptor ,Halfords order code L50AJ and get cables to connect it to your graphics and sound.Your card must have tv/video out/in socket.
  7. roll1
    21 Sep 2004
    uk
    Just saw your posting infernis and that would be the cheapest way especially if you have spare cables lying around.Been that used to s-video i never thought of that.
  8. Slink
    Slink B7
    7 Oct 2001
    Middlesbrough - UK
    So using this method, I should in theory be able to run my gamecube through my monitor, using scart... with no problems?
    Its an Iiyama 1403
  9. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    Reading
    if it outputs in RGB, with timing that the VDU can cope with yes.
    I think a good CRT would have no problems with PAL-M timings. note the word think. I never really paid attention when we were looking at TV it bores me, but i can say, if your console dosen't output in RGB, it won't work.
  10. Slink
    Slink B7
    7 Oct 2001
    Middlesbrough - UK
    Well I'll be going from RGB cables into a scart adapter which I would normally use with the portable tele, But then from the scart staight to vga by making a cable,
    So hopefully I will see a result, Ill get onto this in the morning when I have the bits at hand and a working soldering iron, as mine just dosent like heating up
  11. Slink
    Slink B7
    7 Oct 2001
    Middlesbrough - UK
  12. BjD
    BjD What's a Dremel?
    10 Apr 2003
    Derby, UK
    CRT's wont work at TV resolutions, at least none of the ones i have do :) If its a 'Multisync' then it should work, check it runs at TV freqs (15kHz horiz IIRC). Otherwise you could get one of those TV>VGA convertor box things.
    SVid to VGA might be tricky, I think Scart to VGA would be hella easy in comparison tbh.
  13. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    Reading
    i thought for the last 10 years they vritually all were multisync
    tft's of course arn't
  14. noobidoo
    noobidoo What's a Dremel?
    8 Jun 2004
    vaasa, finland
    sory to reopen this thread but
    i want to go from a dvd or a vhs to my monitor a "Samsung Syncmaster 957p"
    so from scart to vga or rgb whit h/v sync sepretly vga is esyer from what i have read.
    Sory for crappy crappy English so sleepe. :geek:
