Displays Screen Flicker
Discussion in 'Hardware' started by steleet, 16 Nov 2010.
  1. steleet
    steleet Did he death?
    22 Oct 2009
    Hey guys I bought a 23" Samsung SyncMaster PX2370 LED. On some games like Civilization V, Stalker, and Crysis the screen will flicker at higher resolutions. Most other games run fine though. Does anyone know what might be causing this to happen?
  2. quirkalfeeg
    quirkalfeeg Its a trick...get an axe.
    6 Nov 2010
    Strange - my Samsung 22" 2232BW also flickers on and off all the time..tried the monitor hooked up to a second pc with a different cable and still flickers...knackered me thinks.
    No idea about your problem is though - has it always done it or is it a new symptom?
    What Graphics card are you using? Have you googled for similar problems?
    Standard IT support questions: (!)
    Have you tried reseating the graphics card?
    Tried a different DVI cable?
    Could this be an electrical noise thing? (Clutching at straws)
    Q.
    edit:Bad spelling
  3. steleet
    22 Oct 2009
    Well before I got this monitor I was just using my JVC 720p LCD TV. And even though the native resolution of it was lower it could still display 1920x1080 no problems. Well it at least didn't flicker. I'm using HD 4870 for graphics.
  4. Bartaggio
    Bartaggio Minimodder
    3 Apr 2010
    Might be your refresh rates?
  5. steleet
    22 Oct 2009
    Yeah but I thought Vsync took care of that stuff.
  6. ian8415
    ian8415 What's a Dremel?
    2 Dec 2009
    Might be stupid but is it the fps?
  7. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    turn Vsync of and try it
