ok got the media pc working, but even though screen saver is spose to come on after 1minute it dosnt. the only way screen saver works is if i click preview any help on this (i thought a screen saver was fairly simple)
First I'd make sure the mouse isn't stuttering, optical ones do that sometimes. Then, try a default screensaver, perhaps the one you're using is incompatible somehow. Lastly, I'd check to see if there are any programs running that might be blocking it, the way WMP does while it's playing.
right cheers, all programs are closed and tried a different screen saver with no luck , and the mouse isnt connected i am using a remote (imon) maybe its set to always search for a signal?
