Windows Screenshot a DVD?
Discussion in 'Software' started by Krikkit, 3 Aug 2003.
  1. Krikkit
    21 Jan 2003
    Hi, i'm using IntervideoWinDVD as was bundled with my MoBo and i want to screenshot a DVD, but every time i try to paste it into an image editor it shows a black screen if the DVD isn't playing; the image is un-editable if it's paused; and a moving picture if the film is left to play. Can anyone help?
  2. sik
    sik Banned
    18 May 2003
    Disable hardware acceleration.
  3. Krikkit
    21 Jan 2003
    Disable GFX card acceleration :confused: isn't there some simpler way of doing it?
  4. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    Should be an option somewhere in WinDVD, I know that in PowerDVD and NVDVD there is. I would imagine all DVD software has this somewhere.
  5. Krikkit
    21 Jan 2003
    There's no option i can find in WinDVD - the only hardware acceleration option i can find is "Hardware motion compensation" and that doesn't work. :waah:
  6. severedhead
    19 Dec 2002
    When I use Hypersnap DX-4 to take screenshots I get the exact same problem, however in Hypersnap there is a "Special Capture" feature specifically for DVD or DirectX kinda stuff. This feature works perfectly for taking shots of DVDs. See if you can find it in whatever software you use to take them.
  7. Krikkit
    21 Jan 2003
    It doesn't have that either - think i'll get a copy of Hypersnap and do it that way... Thanks
  8. tk421
    tk421 Idiot.
    15 Jan 2002
    ditch windvd cause it reeks, and use power dvd without hardware support. thats the best way to do it.
