Scythe Round Shaped 140mm Equivalent Sized 120mm Case Fan
Discussion in 'Industry News' started by Guest-16, 1 Sep 2008.
  1. Guest-16
    Guest-16 Guest
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    And you'll need to cut the 120mm case holes bigger or 90% of the extra flow is wasted. I don't think this excites me. :yawn:
  3. EnglishLion
    EnglishLion working for the good of mankind...
    2 May 2008
    If using it as a case fan. They also mention it as usable on a CPU heatsink, here it might be a better application. But as a case fan I agree with you, it will also stick out a bit as the fan exceeds the limits of the screws so you might also find that it doesn't fit anyway even though the screws match up.
  4. DarkReaper
    DarkReaper Alignment: Sarcastic Good
    9 Jan 2004
    I'd be interested to try it on the side of a Scythe Ninja or the like, where all the airflow could be used...
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I think it would overlap and be wasted (Ninja = 110 x 110 x 150mm high). I've heard of people fitting 92mm fans to the Ninja (I think when their memory got in the way of a 120mm fan) without noticeable performance hit.
    Where I might be tempted to fit one would be on the back of the upper hard drive bay in my P182, blowing air at the northbridge and passive GPU. But a slow 120mm is doing a good job there already.
  6. EnglishLion
    2 May 2008
    It does seem from the pictures that they might lend themselves best to a DIY fitting within a case, the holes seem quite accessable for ties etc.
  7. prosser13
    prosser13 Hasn't got a Dremel!
    29 Mar 2008
