Portable SD card class speed make a difference?
Discussion in 'Hardware' started by sotu1, 21 Jul 2008.
  1. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    http://www.sdcard.org/about/speed_class/
    buying a new SD card for me homebrew DS, planning to run quake 2 on my DS ya see, as well as plug in a load of my music. Just a quick qusetion really to ask if you guys think faster class speed SD cards actually make a difference or not? And, would it make a difference on an NDS running quake 2?
    Cheers guys,
    sotu x
  2. NaNeil
    NaNeil What's a Dremel?
    27 Jul 2007
    They definitely do on my camera. It can record video constantly, but unless I have a high-speed SD card inserted, only bursts of around 12 seconds are possible until the internal camera cache fills up. Not sure how it would affect Quake though...
  3. Krikkit
    21 Jan 2003
    I don't think it'll be too big a factor tbh mate - as long as you can manage 5MB/s or so, it'll be fine imo. :)
  4. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    I like to use Class 6 cards for my digital cameras... but for what you're going to be using it for (and assuming there's a fairly substantial price difference between them), I agree with Krikkit ;)
  5. jawad
    jawad Mr Meter
    24 Jul 2008
    SD card speed does make big difference
    when talking about SD card speed, look at both write speed and read speed. An example of High Speed requirement would be a high definition SD card based camcorder e.g Canon HF10. This camcorder records 17mb every second so Class 4 SD card is the minimum requirement, that would allow the camcorder to write 17mb of date every second. Otherwise the camera can't record in high definition and default to lower resolution video capture. Similarly if you are running an application off your SD card then you need to have good read speed on the SD card otherwise you can't run the application from it. Hope that helps :thumb:
