Electronics Searching for power sockets
Discussion in 'Modding' started by blue_lawnchair, 3 Oct 2005.
  1. blue_lawnchair
    blue_lawnchair What's a Dremel?
    25 Mar 2005
    Hello everyone. Ok what I am trying to do is an interconnect on the back of my case for my Eheim 1048 pump. I am going to use the 110v pump and not the modded one so I can turn it off or just leave it running if I want. I just don't want the cord hanging out of the case if I need to move it. So I want to wire the pump to a connector from the inside and have it so I can plug in a power connector in the back. Same as the power cable on a power supply or along those lines. I found what I was looking for here www.designnotes.com , the problem is I would rather use something better look. I looked sereral places but I am not sure what to look for that in a connector. One place I found was herewww.lemousa.com but again I am not sure if they would work. Thanks for your time and any help that I can great.
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    How about a good ol' figure of eight?
    Sorry about the funky angle, but it's on the PC I'm using justnow :thumb:
  3. blue_lawnchair
    25 Mar 2005
    You know I forgot all about the connector, it's better that the power supply connector but still looking for something unique. Thanks for the help. You know the more i look at it the better it gets. I could get one for them for Monster Cable or the like. Thanks.
  4. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    You could just hack up the power supply to a mains connecter inside your pc?
  5. ElThomsono
    18 Mar 2005
    *grin* Been there done that, got electrocuted :duh:
    It did look cool though... :)
  6. blue_lawnchair
    25 Mar 2005
    The reason I am doing this is to have the pump independent of the power supply all to gather. Kinda the same way Modsquad is doing in his project. I just want to be able to unplug the pump for the back without the cord hang for the case.
  7. ElThomsono
    18 Mar 2005
    That's exactly why I did it, glad to report it works perfectly. And with modern thermal protection you don't need to worry about it falling out and your CPU frying :)
  8. blue_lawnchair
    25 Mar 2005
    I really am looking for a screw down connector like the one's you see on the Hiper power supply here www.frozencpu.com.
  9. blue_lawnchair
    25 Mar 2005
    Just a small observation ElThomsono but are a fan of Metallica?
  10. ElThomsono
    18 Mar 2005
    Hell yeah :rock: :D
    I really like that connecter BTW, but have no idea where to get one :sigh:
    Maybe if you emailed them very nicely.....?
  11. Confused Fishcake
    25 Sep 2005
  12. g0th
    g0th What's a Dremel?
    12 Apr 2005
    The connectors on the Hiper PSU are microphone connectors, such as for CB radios and similar, you should be able to search up the usual electronic suppliers in your part of the world for those.
    For your power loopback connector i would just stick with the standard panel mount earthed IEC connectors which should be easy enough to get too.
