Planning Searching for touch powered accesories for fans
Discussion in 'Modding' started by Soul_analyzer, 28 Jun 2013.
  1. Soul_analyzer
    Soul_analyzer What's a Dremel?
    26 Sep 2012
    Hello everyone. I need some suggestions where I can find some stuff I need. Two years ago I modded my Thermaltake Armor Jr and made this to the side panel
    To do that I used the system that was on this
    Now that I have purchased a new case the Aerocool Xpredator White I want to do the same thing . I want to make all 4 fans of the side panel of the Aerocool Xpredator to be powered by touch.
    Now I can order the same product of silverstone http://skinflint.co.uk/silverstone-cfp52b-4-in-3-module-a393500.html so i can use that system but paying more than 120€ just for that system seems quite stupid.
    Is there a store that sells only the touch system or something similar like that so I can make my mod.
    Is there a way I can make my own touch powered system for 4 fans.
    As you understand I want to do this so I dont have to unplug and plug 4 fans everytime I open the side panel of the case.
    Thanks in advance.
  2. Nexxo
    23 Oct 2001
    Google for (spring) contact connectors and make your own.
  3. miller
    miller What's a Dremel?
    10 Jun 2013
  4. Cheapskate
    13 May 2007
    What Nexxo said, Or make some using folded metal like the negative side of a battery terminal.
  5. Soul_analyzer
    26 Sep 2012
    You are right . That's excactly what I need but where the hell do they sell those stuff cause i cant a store... :(
  6. Nexxo
    23 Oct 2001
  7. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Find some old mobile phones and desolder the sim card contact assembly. Etch your own PCB. Hey presto.
  8. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    There's also the option for a miniature limit switch.
