Scratch Build – In Progress Server Case 2.0
Discussion in 'Project Logs' started by ProAce, 26 Jan 2014.
  1. ProAce
    ProAce What's a Dremel?
    13 Jan 2014
    Hereby I present to you: The "Server Case 2.0"
    This is the restart of my "Server Case" build, which I only posted on dutch fora.
    First things first, I will introduce myself. I'm Yorick, I live in the Netherlands, I like working with computers a lot, and also the making of my own pc cases. Enough with the talking, lets start with the build!
    Which Hardware?:
    • Intel® Desktop Board D915GLVG
    • 2GB DDR ram
    • 4x SATA Schijf (3x 80gb, 1x 40gb)
    • 2x IDE Schijf (2x 120gb)
    • Cooler Master Hyper TX3 EVO
    • FSP 300-60PN (PF)
    • 120 mm fans I still have to buy
    • A hole lot of cables
    What do I have to do:
    [ x ] Get all the hardware.
    [ x ] Getting the wood, and making it the right sizes.
    [ ] Make the holes for the casefans, and mod them with resistors.
    [ x ] Mount the casing.
    [ ] Mount all the hardware.
    [ ] Replace broken hardware with working ones (I break a lot of it).
    [ ] Get Plexiglas for the cover.
    [ ] Putting it all together.
    I probably forgot something, but I will change this during the process.
    What will it look like?:
    Here the most important part, the renders (in sketchup).:
    In the cover, there will come an plexiglas plate (if affordable).
    For who wants to see it in full 3D, the sketch up is downloadable here:
    http://www.fileswap.com/dl/XIKfHv177r/
    Cutting straight by using a wooden plank.
    When I was ready with the wood, I spread it out.
    Attaching all the sides to the bottomplate.
    attaching all the distance pieces to the base plate. Then I tried if it fits, and it does! Only I lost my screws :(
    Cut a hole voor de PSU, and it fits perfectly.
    Put it all together, and it looks nice. I only need to drill the fan holes, but this will come when I have two of them.
    Thats it for now, untill the next time!
  2. ProAce
    13 Jan 2014
    It has been a while, but it's time for another
    Update!
    This time I almost finished the outside of the build, and did some sleeving.
    For which I want to thank sw333t (dutch fora user) who send me 38 meters blue camo paracord :D
    First I made a hdd cage, just like the rest of the build it's a wooden one:
    It can contain 4 hdds and I decided to only use the sata ones.
    Behind the cage will be some fans, the fans I wanted to use got wrecked so now i have to get or 2x a 92 mm fan or 1x 120 mm (by which i need to maken a new sidepanel but which is better re useable in a new build)
    For the cable management I made a little plank to put al the unused cables behind:
    On top of this I will make another plank to get it al clean and nice, ofcourse with a fan hole for the psu fan.
    Next I cut the holes for the fans:
    The little ones are wrecked :(
    As you can see I need to make an entirely new plate for the side if I order an 120 mm.
    Then it was time for some sleeving!
    I sleeved the:
    -20 pins atx
    -4 pins atx
    -2x 120mm fan
    -1x 92mm fan
    That are all visible cables, and it really hurts to do heatshrinkles sleeving :(.
    So i found it enough, the rest of the sleeving will be used in my next build.
    Than I got some more renders, also from sw333t!
    And the overview of how it is right now:
    That's it for now, until next time!
  3. ProAce
    13 Jan 2014
    Time for another update :)
    Have done a lot of work on the case, so it's almost finished :D
    But I wrecked my hardware, so I won't be able to use it as server for the coming time.:mad:
    But further about the case:
    First I got some DDR Ram, which apparently was ecc :grr:
    And one of those killed my mobo :mad::mad:
    Than I made a new HDD cage because the old one wasn't right.
    (top)
    (bottom)
    After that I started on the top of the case, with a hole in the middle where a plexi plate will come. (2mm plexi)
    Finished the side panel :)
    Replaced the two (broken) 92mm fans with one 120 mm, which is a lot quieter on 5 volt :D
    (Without cover)
    (With cover)
    An impression of how the cables will come when it's all placed. I'm only missing a HDD, where have I laid that thing down :confused:
    And last but not least, I made my own super bright LED Strip :)
    As I said in the startpost, I have ruined a lot of my hardware :grr:
    Rest in peace:
    - Motherboard
    - 4 fans
    - 1 PSU
    - 3 hard drives
    Now I go searching for new hardware!
    Till next time :)
