Other Server will not turn on!!
Discussion in 'Tech Support' started by ferrish07, 20 Dec 2011.
  1. ferrish07
    ferrish07 Samba!!
    18 Dec 2010
    Hi people I'm hoping someone can help!!
    I have just received an HP ML310 G3, after some tinkering I got it started and booting by removing a defective RAM stick, shut it down and went to bed. The day after it will not power on at all!
    motherboard has a green light and the power light on the front is solid amber which is normal
    so far I have tried:
    removing and replacing RAM
    tried a different PSU
    disconnecting everything one by one
    disconnecting the power lead and holding the power button down for a min or two
    All with no joy it sits there tormenting me!
    Any ideas are welcome please any advice!!
    Thanks in advance
  2. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    Was it working when you received it?
  3. ferrish07
    ferrish07 Samba!!
    18 Dec 2010
    no, was turning on but not booting to OS, removed a RAM stick and that worked fine, starting using it and then shut it down for the night, returned the following day and nothing since
  4. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Did you buy it new or used or ?
    I'd be contacting the seller / retailer...
  5. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    is it that it will not power up at all or do the fans spin then nothing? or power slightly and fail? or something else?
  6. ferrish07
    ferrish07 Samba!!
    18 Dec 2010
    was given to me used, had not been on for 6 months prior but last person said was working fine.
    No power at all, motherboard light is green and light on front is amber. no fans spinning no life at all. was starting to think maybe the mobo is dead but is shows a slight sign of light in that the light is on green when power is connected
  7. Votick
    21 May 2009
    Aye I'd say mobo or PSU, Try pulling the PSU out and giving it a clean on the contacts. Unless its not a removable PSU in which case that server really isn't worth saving.
  8. Mojo
    Mojo Multimodder
    18 Nov 2011
    Could be the switch itself?
    Normally with the HP servers... even if the board is knackered it'll power up the fans at full pelt and stay at full pelt.. not do nothing at all....
  9. ferrish07
    ferrish07 Samba!!
    18 Dec 2010
    I haven't tried playing with the switch/button itself yet, I will try this evening and post my findings
    knowing my luck with this thing its probably the switch
  10. ferrish07
    ferrish07 Samba!!
    18 Dec 2010
    still have nothing, still seems very strange how it wont turn on after being used, restarted and then controlled shutdown. im out of ideas
  11. saspro
    saspro IT monkey
    23 Apr 2009
    Does the power button click when pushed?
    Is everything 100% in the correct place (especially memory in the correct channels)?
    Is the PSU in the correct slow at the back?
    Is it still showing the orange light?
    Have you pulled the CMOS battery & left it for an hour (unplugged from the mains as well)?
  12. ferrish07
    ferrish07 Samba!!
    18 Dec 2010
    Yep tried all that!
    Im starting to thing that the mobo has died but part of me thinks not hence the 2nd opinions needed!
    starting to think it wont be joining the other stuff in the cabinet at this rate!
  13. towelie
    towelie How do I Internet!!
    1 Sep 2011
    RAM ECC or NON ECC some server require it some don''t?
  14. ferrish07
    ferrish07 Samba!!
    18 Dec 2010
    RAM is ECC
  15. towelie
    1 Sep 2011
  16. ferrish07
    ferrish07 Samba!!
    18 Dec 2010
    thanks have come across that link before which led me to believe it might be the switch but haven't tried anything yet.
    It has an amber light on the front which is the standard standby light i assume and the mobo light appears green inside with power hooked up so all seems good inside.
    I also removed everything one by one and replaced one by one and still the same.
  17. ferrish07
    ferrish07 Samba!!
    18 Dec 2010
    Quick update, I tried the old screwdriver on the pwr switch pins to see if it was the switch that wasnt working but still nothing starting to think I will have to admit defeat on this one
  18. korhojoa
    korhojoa durr
    31 Oct 2003
    What does iLO say?
  19. ferrish07
    ferrish07 Samba!!
    18 Dec 2010
    Sorry for slow reply but moving house and revising has taken priority!! after more tinkering and diagnosis the mobo seems dead! hoping to pick a cheap one from eBay!
    Thanks for all your help/advice!!
