News Set up a RAID 5 array on the Interweb
Discussion in 'Article Discussion' started by Tim S, 24 Dec 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. badders
    badders Neuken in de Keuken
    4 Dec 2007
    This would be fine if my internet speed was greater than 300Kilobits/sec!
    There's the bottleneck!
  3. nakchak
    nakchak What's a Dremel?
    20 Mar 2005
    just a few fairly hefty flaws with the plan....
    free ftp accounts tend to have transfer limits, i would imagine that the majority of your available bandwidth will be used to sync and send parity data
    response times will be horrible, as will file searches.
    i mean proof of concept is fine, but they could juat have easily built a raid5 array from 40 floppy drives and say the same things,
    but i mean having a convoluted software raid setup just seems dumb to me, we all know software raid doesnt work very well, compared to the full fat server raid cards
    unless you have a syncronus connection (same speed up and down, which you wont have in the UK unless you have a forked out serious £££ for an SDSL line) then the system is a non starter, never mind that using your net connection like that would probably classify you as a server, which is against the the T&C's of most domestic ISP's in the UK.
    frankly if you want cheap serious distributed storage consider using amazons S3 services, or just follow the how to build a linux server guide on bit, will get something far more usefull, and you can run games servers off it as well :)
  4. Starfighter
    Starfighter What's a Dremel?
    4 Apr 2004
    *FREE*, reliable, secure offsite backup solution? yes Please!
  5. DeX
    DeX Mube Codder
    22 Jul 2002
    Haven't you tried mozy yet?
Tags: Add Tags
