Small Form Factor SFF buying advice
Discussion in 'Hardware' started by Gunsmith, 13 May 2019.
  1. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    alright, i'm on the hunt for a quiet small form factor to essentially be my PS machine and run my Cintiq. I'm seeing quite a few out there that look like they'd do the job but im concerned about the gpu's on them not having the grunt to essentially run hardware rendering in PS and at print resolutions. would be nice if it could run a second monitor as well but that's pipe dreaming.
    I'm not really looking for a bank breaker either so gaming stuff like the gigabyte brix is a little out of my budget.
    any suggestions?
  2. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I believe our very own @Gareth Halfacree has just done a SFF megatest for PC Pro (I think), so that might be a good place to start...
  3. Gunsmith
    23 Sep 2005
    subscription only.
  4. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Perhaps you could ask Mr H for some pointers?
  5. Arboreal
    21 Jan 2011
    I think those little beasties may be too low powered and inflexible for heavy duty image editing and content creation. /2p
    Something compact in ITX may do the trick.
    The Asrock A300 barebones is meant to be pretty good with the Ryzen 2400G APU popped in it
    Puget Systems in the USA have a series of benchmarks and discussions on system requirements for Photoshop. e.g. This one
  6. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
  7. Gareth Halfacree
    4 Dec 2007
    I did!
    I mean, you can always pop along to the newsie or supermarket and 'browse the shelves' if you have to...
    For the job in question, and assuming size matters, I'd probably say the Intel glowy skull thing is the best bet - gets great CPU and GPU performance from the combined Intel/AMD processor, and ne'er mind dual-display 'cos the thing supports six simultaneous displays - but if the Brix is at the top end of the budget then the glowy skull is likely over the top.
    The big question, though, is how much of Photoshop is actually GPU-accelerated? I know there are only a handful of filters in GIMP that use OpenCL, with the rest running entirely on the CPU. It may be that a system with a more powerful CPU but weaker GPU will perform better for daily Photoshop use than vice-versa - and most USFF stuff tends to be CPU-focused (most don't even have the option of a dGPU, for starters.)
    Arboreal and bawjaws like this.
  8. Arboreal
    21 Jan 2011
    I did, and was impressed by the amount in there, I thought it was ironic that there was a review a few pages later for a Lenovo SFF workstation PC done by someone else. Lacking in joined up thinking!
    Interesting point about GPU acceleration, it's been touted for ages, but I understood that not a lot of what PS does is assisted that way.
  9. Gareth Halfacree
    4 Dec 2007
    That is a bit daft - though, in the editor's defence, the group test was supposed to be for an issue or two earlier, but when he said "hey, can you source, photograph, and review at least ten-mini PCs in the next two weeks" I rather sensibly said "absolutely bleedin' not."
    Arboreal likes this.
