here is my Vector RS build Shadow Black ! Intel I9 9980 Extreme @5GHz allcore direct DIE cooled ASROCK X299 TAICHI CLX Mainboard 32GB Teamgroup T-Force Xcalibur 3600MHz Quadchannel XFX THICC III 5700XT Fractal Design Vector RS Blackout Fractal Design ION+ 850 W PSU Cablemod full sleeved PSU set Cablemod PCIE riser (which is awesome !) EK WB sTR4 Velocity (yes its a TR4 cooler ^^) converted to a X299 Intel cooler with custom brackets and a bit editing to the bottomplate. You can switch it back to a TR4 ones without any trouble! Cooling performance is perfect! EK WB FLT 240 Reservoir pump combo mounted to the front radiator 2x360 EK WB Coolstream 360 Radiators EK WB Torque Fittings 16mm EK WB Vardar EVO A-RGB Fans 16mm Acryl Hardtubes all is controlled by a EK WB Connect Watercoolingcontroller which works great with the early EK Software ! The Name Shadow Black is the same like the foil from 3M You can exchange the GPU without draining the loop ! That makes this system super flexible ! All parts are wrapped with the 3M foil !
No pictures for me, are they member only links as if I copy the url and try to view it, I'm taken to a website for logon
No pictures for me too. You can paste pictures or use external link like imgBB website. Great job In your opinion, is it good to place fans that blow directly on the distro plate (reservoir) and block airflow from going to the back of the case ?
I like it, especially when turned off mostly because of the ram RGB, as you can see well the job done with the black grey and red combo. I like the vinyl too, in the not so distant past i was even thinking to use it on parts of my car but a texture like that work better on smaller things like your Pc Case . *grammar edit
