If they're using the reference PCB layout it shoud be the same as a HD4850 (it's practically the same graphics card).
Anyone know if they will fit in most htpc cases? such as this http://www.newegg.com/Product/Product.aspx?Item=N82E16811163117
I'd say it should fit in that case, since a stock HD4830/50 has a length of approx. 24 cm (9.2"). The Silverstone LC13-E is approx. 43 cm (17") deep and the add-in card area is located across the middle drive bay. The only problem could be the support strut.
