Graphics Should I get a 8800gts
Discussion in 'Hardware' started by badermans, 25 Dec 2006.
  1. badermans
    badermans What's a Dremel?
    8 Apr 2006
    Got some money for xmas. So im wondering if its worth me upgrading from a x1900xt to the 8800gts? At the moment i have a 19 inc tft whaich i do plan to upgrade and im gonna go the vista way as well.
    Or alternatively i could go for a platform change and go for a c2g set up. But this will mean alot more money and i'll have to wait longer to get a larger screen.
    Need advice asap as im gonna spend my xmas money on something stupid if its left in my hands for to long.
  2. kingdavies
    kingdavies Minimodder
    29 Aug 2004
    I would say you would only notice a difference betweeen the 2 gfx cards at a higher resolution which you won't get on a 19" screen. So on the current screen no its not worth upgrading.
  3. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    No. Save your money for a complete overhaul in 6 months time. Your X1900XT is still very fast. :)
  4. Mighty Yoshimi
    Mighty Yoshimi Motormouth
    4 Sep 2006
    Only advantage just now, is that the 8800gts will (probably) assuming Dx10 is a success give you better visuals, in most or all games.
    Stay with the X1900 Wait to see how the graphics compare between DX9 and DX10 and make a decision then, and by that time the card might be retailing for 50% less.
  5. badermans
    8 Apr 2006
    The only reason i wanna get one is i can pick one up for a good price. But if i wait too long i wont be able to get it at that price.
  6. oasked
    24 Aug 2005
    However good the price is now, it'll still be cheaper when you get round to buying it later. :)
  7. BFGunrunner
    BFGunrunner What's a Dremel?
    13 Mar 2006
    Yeah don't bother getting it now. You might not even see a big diffrance... You should wait till the 8900's come out and you'll be happier that you waited a bit. :)
  8. dbarber20
    dbarber20 What's a Dremel?
    3 Jan 2007
    I was thinking of getting a geforce 8800GTS and was wondering if a pentium 4 670 3.8 ghz would run well.
