Notebooks Should I get this laptop?
Discussion in 'Hardware' started by enfluence, 5 Sep 2012.
  1. enfluence
    enfluence Minimodder
    31 Aug 2009
    I've found a really good deal on a laptop (well I think it's good lol) and I'm wondering if you guys think I should go along with it
    Here is the item
    http://www.ebay.co.uk/itm/271047402218?item=271047402218?_trksid=p5197.m462
    The things I'll be using it for include internet browsing, watching youtube and possibly gaming but I'm not sure what kind of gaming I could get on this? is CS:GO a possiblity or is that too far?
    or if there's something around the same amazing price, say 350 being max can u recommend me one?
    thanks!
  2. Deders
    Deders Modder
    14 Nov 2010
    Item has been removed?
  3. fuus
    fuus Misses Rep Bombs
    4 Dec 2010
    Almost certainly won't run CS:GO at all. for internet, Youtube and maybe TF2 at a push it should be fine!
  4. enfluence
    31 Aug 2009
    :/ damn any more opinions?
  5. enfluence
    31 Aug 2009
  6. Deders
    Deders Modder
    14 Nov 2010
    Unfortunately that deal is supposed to end yesterday, but I'm not sure about ebay rules, if it has a buy it now button you should be able to get it for that price.
    The 630M comes in 3 flavours but all of them will be more powerful than an onboard solution. I can't see you getting much faster for that price.
    The benchmarks on the page itself don't say what settings the games are running at. I'd presume not the highest.
  7. enfluence
    31 Aug 2009
  8. Deders
    Deders Modder
    14 Nov 2010
    Looks like the same laptop but for more, it's the same model number but Acer do update their models every now and then with better components.
    Graphics performance will depend on which flavour of GT630 they have used.
  9. murraynt
    murraynt Modder
    6 Jun 2009
  10. enfluence
    31 Aug 2009
    Sounds like a horrible deal compared to the one I posted lol the processor given doesn't even have turbo boost unless you pay extra and by that point its already well over 600 for a 11.6 inch screen and a somewhat better graphics card lol.
    Deders the one i posted has 8gb ram and turbo boost to 3.1 ghz on the cpu
    Is there seriously no better deal than this? lol I dont mind if its refurbished, anyone?
  11. McDuff32
    McDuff32 Minimodder
    5 Aug 2011
  12. enfluence
    31 Aug 2009
  13. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
  14. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    I recommend the Novatech one too; I have a similar one, order it without the OS and buy it seperate with a student liscence or discount from your work if you can :p
  15. Zoon
    12 Mar 2001
    The nice thing about the one I mentioned is its got a Hybrid hard drive in it. For Windows booting and commonly used apps they load just as fast as an SSD although you get 500gb storage behind it.
  16. enfluence
    31 Aug 2009
    Cool thanks guys I'll definitely look into this...sounds like a really good deal, question though would the lack of a quad core limit me on some games...like battlefield 3 for instance.
  17. Deders
    Deders Modder
    14 Nov 2010
    This Might be a good option if you are on a budget.
  18. fuus
    4 Dec 2010
    The graphics card will always be the limiting factor... for <£600 you will not be able to play BF3 at all....
  19. Deders
    Deders Modder
    14 Nov 2010
    You might on lowest details, so long as the GPU is above a certain level
  20. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    To be frank, though, the graphics card is always going to be limiting factor in laptops - unless you go for one of the stupidly expensive Alienware laptops.
