Other Should I keep it or should I chuck it?
Discussion in 'General' started by earlydoors, 22 Aug 2011.
  1. earlydoors
    earlydoors Minimodder
    12 May 2009
    I'm talking about the box to my monitor, handy if I want to resell, but the box is so big it doesn't fit through the entrance to my loft and so has to take up valuable and limited closet space. I want to chuck it, but usually I never chuck my boxes incase I want to resell...What would you do?
  2. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Chuck it, when you want to sell the monitor just make sure you've bought a new one first and post it in that box.
  3. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Can't you just collapse the box?
  4. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    I keep boxes for a few weeks to make sure the part doesn't go belly up. Then I pitch it. As Steevo said, mail it out in the new box when you replace it.
  5. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    This?
  6. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    flatten the box and use it as insulation .. or a make shift bed, or if you are really adventurous add wheels and use it as a carbon free commuting vehicle
  7. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    +1
    I still have the box in the loft from the CRT I bought in 2002. Its next to all the boxes for all the hardware I still own. The CRT has gone now though! I have still kept the box as its a decent size for when I finally get to move house!
  8. Kurze
    Kurze What's a Dremel?
    18 Aug 2011
    Chuck it. I'm in the exact position described above, selling my old PC to my mate. Just means I'm going to be sending out a machine in an Antec 300 case inside a HAF X box. Hope I have enough padding material...
  9. Krikkit
    21 Jan 2003
    Most TFT boxes will be stuffed full of polystyrene. Pretty pointless keeping a box only to throw all that packing out.
    I'd keep it, but fill it with junk (what you can fit in there).
  10. Hawklan
    Hawklan What's a Dremel?
    4 Feb 2010
    Chuck It
    You can always make up a box if you need to. I've done that many times over the years and find they end up being stronger than the original (must be all that tape)
  11. Jipa
    5 Feb 2004
    I saved my monitor box, which was an excellent thing as I had to RMA it at the age of just under 3 years... During the time I also moved three times, so I was happy I kept it.
    That said, I don't usually save empty boxes and if you don't have enough room, just ditch it. Most likely you'll never miss it :)
  12. earlydoors
    12 May 2009
    Ok, thanks for the tips lads, I had thougght of flattening it, but as it was full of all the polystyrene packing and whatnot I'd have just have to chuck all that anyway sooo....I'm just going to chuck it!
