Should I try now?
Discussion in 'Hardware' started by AnarKy, 16 Jul 2004.
  1. AnarKy
    AnarKy What's a Dremel?
    6 Jun 2004
    Im getting bored of waiting for the cash to buy some new stuff so Im wondering whether try try clocking this chip now.
    AMD Athlon 2600 XP TB
    512 DDR PC2700 Twinmos
    Abit-NF7 v2.0 nF2
    400w PSU
    WaterChilled
    Should I raise the FSB by 1 now to see if it boots and see how far i can get?
  2. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Go ahead and push up the system and see what you can do-you probably wont be able to squeeze out that much more performance out of the system using only PC 2700 RAM, but you should get at least a slight performance boost. :)
  3. AnarKy
    6 Jun 2004
    Just raise the FSB?
  4. k3nn
    k3nn What's a Dremel?
    2 Feb 2004
    pretty much yeah, jsut make sure your ram can cope with the speed as its only 270o, also put the multi up if the fsb wont go to far
  5. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    The worst that can happen is the system will crash, just reset the CMOS and try again.
    Go for it dude :thumb:
