Small Form Factor Shuttle Cooling
Discussion in 'Hardware' started by deathtaker27, 11 Sep 2011.
  1. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    hey guys and thanks for reading this,
    I have recently purchased a shuttle PC from the market place, its socket 775 and is running a core2duo.
    However I need to find a cooler that is no taller than 1.5 inches / 4 cm high and cant be more than 9cm wide, which im struggling to find.
    If you know of any lowprofile coolers that fit this description please can you tell me
    Kind regards,
    DT.
  2. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Any way of getting a AIO unit in/externally mounted?
  3. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    sorry if this sounds ignorant but what is an AIO haven't heard of one before.
  4. fdbh96
    29 May 2011
    Sorry, it's an all-in-one unit such as the corsair h50. It leaves the motherboard area a lot more open and you won't have any clearance issues. However it has a 120mm radiator and you need a 120mm fan space somewhere.
    Just remembered what a shuttle case is and ignore everything I've said, its probably not a realistic idea. Just look for a low profile CPU cooler :)
  5. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
  6. MSHunter
    MSHunter Minimodder
    24 Apr 2009
  7. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    bought second hand from marketplace
  8. MSHunter
    MSHunter Minimodder
    24 Apr 2009
  9. Mimic
    Mimic What's a Dremel?
    19 Jul 2004
    if your shuttle has a shuttle motherboard, have you checked the compatibility of a non shuttle cooler? in my experience, they screw into the base of the case and have a weird location for the mounting holes.
  10. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    nope its not i bought it with a zotac 620i (i think) motherboard inside it.
