Small Form Factor Shuttle - Some Changes Made
Discussion in 'Hardware' started by richman, 28 Feb 2004.
  1. richman
    richman What's a Dremel?
    17 Sep 2003
    there aint no instructions about installing the ice heatsink and fan system onto the cpu or i would have followed them :duh: maybe i could use a diffrent heatsink
    rich
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    There are instructions! I'd take a picture of them if I was at home.
    You havn't looked through the stuff you got with your shuttle :p
  3. phaSe
    phaSe What's a Dremel?
    4 Jul 2002
    theres a shim to protect your CPU core somewhere in the box too.....
    RoB
  4. richman
    17 Sep 2003
    ah is that what that shim is for, will this protect the core will it
  5. Atomic
    Atomic Gerwaff
    6 May 2002
    The shim should help to stop the core from being crushed.
    It mentions all of this in the instructions, you really should read them!
  6. richman
    17 Sep 2003
    i will have a look at them then, cheers
    richman
  7. russdaplaya
    russdaplaya What's a Dremel?
    12 Oct 2002
    :worried: Hope I don't have this many problems with my SN85G4 when it arrives.
  8. Atomic
    Atomic Gerwaff
    6 May 2002
    It's actually quite simple, Im not sure why richman had so many problems...
  9. [twig]clown
    [twig]clown What's a Dremel?
    1 Jan 2003
    Thats what I was thinking. Dont even think I looked at the manual once, well, not about cpu or ICE system installation. On a side note, i use the ICE system, seems great.
    -cLoWn
  10. russdaplaya
    12 Oct 2002
    Just one thing to confirm, I ordered some Arctic Silver 5 with my other various computer components. Is it best to use this AS 5 with the ICE System and my 64 3200+ 1MB?
  11. Atomic
    Atomic Gerwaff
    6 May 2002
    Doesn't really make much difference what thermal compound you use... AS5 will be fine though.
  12. russdaplaya
    12 Oct 2002
    Okay thanks!
  13. alphonsus
    alphonsus What's a Dremel?
    28 Mar 2005
    My Shuttle
    I've got an SN41GV2 - nforce2 - with
    2800+XP
    1Gb 333MHz ram
    40 Gb HD
    DVD-DL/RW
    Hauppauge 350PVR (this one does the viewing - I've got an 1800+XP with 160Gb space elsewhere which does the recording)
    On-board graphics and sound (good enough for SimCity4 and media player!)
    I can recommend a shuttle for either a main or second system - ask someone about heat and Intel P4 chips - you may want to consider an athlon system, AFAIK they are cooler and therefore quieter.
  14. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    Holy thread revival batman! :hehe:
