Modding Side Panel Modding Advice Needed
Discussion in 'Modding' started by Cochise, 1 Dec 2005.
  1. Cochise
    Cochise What's a Dremel?
    1 Dec 2005
    Hi folks. I need some advice. I've got an old handle case that I've done some minor mods to. Nothing fancy, just a window and some lights, a few cool fans. But my other side panel is bare. The colours I've gone with are blue and yellow. Blue lights n fans and yellow cable sleeves and ide cables. I need to know what i need to remove the paint from the panel and what to use to make a stencil?
    I'm new to modding so please explain slowly :)
  2. ARM
    ARM Minimodder
    15 Sep 2004
  3. The_Dude2040
    The_Dude2040 What's a Dremel?
    25 Nov 2005
    if your stripping paint ry to get some nitromors if you can. it's a thick gloopy stuff stips paint no problem. only problem it strips skin too. my advise never sit in a blob of the stuff. you'll know if you do.
    but if you can't get nitromors, then as ARM says use any paint stripper. and if you use and paper a rought grade to get the paint off the thing then a smoother one just to give a nicer finnishes. or use the original paint as the base coat. i think you need something like 800 grit (wet dry paper. avalible from car part places) just to rougth the surface up.
  4. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
    Paint on a case never painted over is so thin a 400 grit sand paper will remove it effectively. Then go up in grits 600-800 after that you'll have bare metal ready for anything you like :thumb:
    Edit: Errm! what he said :hehe: :D
  5. Hellboy787
    Hellboy787 What's a Dremel?
    3 Nov 2005
    So How about if you wanted to paint anonized alumunuim or something like that?
  6. Kobalt
    26 Aug 2003
    Anodized can't be painted it's like a chrome process with acid and stuff but there's someone here that does it i think :worried: *looks left and right*
  7. pingthepiratehobo
    pingthepiratehobo What's a Dremel?
    22 Aug 2005
    i think he means painting over something that is allready anodised, which is completely possible. or im misreading too
  8. Kobalt
    26 Aug 2003
    Oops! My bad, i was under the impression that the case was painted :blush:
  9. Ener
    Ener What's a Dremel?
    17 Oct 2005
    you can make a stencil out of masking tape and thin card, like a cerial box.
    or you can just use tape
  10. pingthepiratehobo
    22 Aug 2005
    come to think of it, i think the case is painted now too - maybe he's talking about other pieces of aluminum?
  11. Kobalt
    26 Aug 2003
    So Coch, is it painted or anodized :hehe:
  12. TJK
    TJK What's a Dremel?
    21 Nov 2004
    ok i have bare steel and i spraypainted it, but i always have problems with the paint scratching, even with like a fingernail. Anyway to prevent this?
  13. Drexial
    Drexial Minimodder
    28 Jul 2005
    you need to use a good primer first
    zinc primers are amazing, especialy for filler jobs
    slow and steady wins the race in painting, start with a misty coat first let it sit for a min, then start layering it on a little at a time, you will have a nice even shiny coat, and dont forget to wetsand the primer layer. what ever is in your primer will show 10X bigger on your paint, so make sure thats smooth. with the primer base and a well cured paint top (enamal bassed paints are more durable but slower to dry, so be even slower and steadyer) will result in a perfectly shiny and durable top.
    and keep in mind, if its a tight fitting part, remember that paint adds alot more then you would think, especialy when done to last.
