Hardware Silverstone MS05 2.5" Enclosure
Discussion in 'Article Discussion' started by Tim S, 10 May 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. iwog
    iwog Linux cursed
    14 Jun 2007
    Typo
    Fixed
    Unless this device has tardis like properties and grows by 240mm when you insert it into the docking bay surely you only have 20mm of purchase.
    Other than that excellent review but my god that thing is ugly. I much prefer the svelt TS01B than the bulbous MS05.
  3. dabb
    dabb What's a Dremel?
    10 May 2008
    Photon torpedoes! Full spread!
  4. Dreaming
    Dreaming What's a Dremel?
    31 Jan 2007
    A photon torpedo hard drive enclosure would be so awesome.
    In fact, bit-tech.net, I think that's a modding challenge! (I would if I had the skills!)
  5. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    I think you mean peace of mind. More coffee, Joe :p
  6. Anakha
    Anakha Minimodder
    6 Sep 2002
    I think this is a great idea. And I'm not the only one. Look at HP's recent line of desktops. They have all come with a "Dock" on the front (Though theirs has a spring-loaded door) for an optional removable hard-drive.
    This is perfect for keeping your personal data/browsing preferences/porn on, and when you are headed out somewhere you simply undock it and use it as an external USB/ESATA drive at your destination (The parent's place, say - though probably not for the porn).
    You could also set it up to be a "System recovery" disk - a larger and more expanded version of a DSL key, say.
    Or you could get a few and use them to swap OSs or major software packages or something.
  7. snark_be
    snark_be What's a Dremel?
    12 Dec 2007
    Check out the Tagan IcyBox IB-266StUSD-B.
    Same concept: a 2.5" disk enclosure with USB2 and eSATA , and a 3.5" docking station.
    However, this one has a flap covering the hole when the disk enclosure is not in.
    Furthermore, the Silverstone protrudes from the front of the case, making difficult to close the door on some cases.
    The IcyBox is flush with the case. It has a spring loaded mechanism. Push it and the spring ejects the disk from the dock.
    The product page is here: http://www.raidsonic.de/en/pages/products/external_cases.php?we_objectID=4811
  8. fathazza
    fathazza Freed on Probation
    20 May 2002
  9. snark_be
    12 Dec 2007
    This is the newer version of the one I wrote about above. Looks great. Too bad I have the other one, the new one looks better. But the old one works really fine!
Tags: Add Tags
