SimCity 4 Killed my computer!!
Discussion in 'General' started by Kevo, 28 Jan 2003.
  1. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    Last Saturday I was playing SimCity 4, I had built quite a large city almost filling the entire area and as such it was slow as hell and it was really beating the crap out of my hardware then all of a sudden it soft rebooted my computer.
    Ever sine that point my computer kept on rebooting randomly in windows, I thought it was a virus at first but my virus scanner could never get to finish its scan run before my computer rebooted itself. I tried to reinstall windows XP but it either didn’t copy/ or couldn’t find files properly or just crashed.
    Cutting a long and painful story short I have found out that SimCity 4 has killed my motherboard! This seems very odd to me but I’ve eliminated everything but my motherboard this gave me a nice excuse the buy my self a nice new Asus A7N8X Deluxe with some Corsair Platinum TwinX XMS 3200LL ram :D
    And the moral of the story? Don’t get to good at SimCity 4 or you might just pay a high price ;)
  2. ToM
    ToM mmmm, blud
    14 Aug 2001
    or just dont play sim city games, not only do they sap your life, they sap your pc as well now. hmmm
  3. Kevo
    9 Sep 2001
    I should get my new mobo today I wounder if it will fix my problem :D
  4. ToM
    ToM mmmm, blud
    14 Aug 2001
    or, you could sue the people who make sim city and gets lots of mobys for all of us :D
  5. westeee
    westeee What's a Dremel?
    20 Jan 2002
    i bieng serious i hade the same prob
    i was playing it them my computer froze up on me
    and from then on it would keep feezing on start up
    i had to completey udjust my memory settings in bios to fix it
    my mobo is a 7vrxp
  6. Cheese
    Cheese Doc
    6 Oct 2001
    It hasn't given my vapo anything to worry about yet :)
    Actually after a bad start I'm beginning to like the game too...
    It's a bit off that a game could hurt your PC, though it was most likely temperature related and waiting to happen (any sustained load would probably have triggered it). You've done things like reseated your northbridge heatsink I take it? I guess it could also be a dry joint somewhere which eventually pulled off on heating..
    Rob.
  7. Kevo
    9 Sep 2001
    westeee: I cleared my bios twice but didnt fix it :sigh: I even tried different ram but still no luck.
    cheese: It probebly was heat related as Sim City 4 was thrasing my computer unlike any game before it and im talking about 40 second between screen updates ;)
    I hadent messed with any cooling tho it was all stock and cooling quite well.
    Meh should get my new mobo today and ill tell you if it works (or not ;))
  8. Kevo
    9 Sep 2001
    Yay mobo has arrived! But its in the office on the floor below me and the lift is broken :waah:
  9. K
    K 528491
    31 Oct 2001
    Any excuse for a new mobo ;)
  10. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    You're lucky you figured it was the mobo, :) I spent £300 odd replacing other bits when i had a similar problem without success until I replace the mobo... Don't want to replace it again, ;)!
  11. six degrees
    six degrees What's a Dremel?
    13 Oct 2001
    uhh, stairs? :eyebrow:
    :p
  12. Kevo
    9 Sep 2001
    Indeed :naughty:
    But im so lazy ;) I got one of the office girls to bing it to me :D
    Well you never guess what....
    IT STILL DOESNT WORK!!
    My memory doesn’t work now well kind of, my error is the same ALL of the time now and that’s during winXP’s memory check during the install. The odd thing is tho I ran a dos memory checker and it reported that everything above 256meg is fubard so basically one of my dimms is dead, I removed the broke one and tried to install winXP again but it still crashes in the same place. :sigh:
    Heh I should get my new ram tomorrow ;)
  13. SilverBullet
    SilverBullet Banned
    14 Oct 2002
    KEVO KEVO KEVO
    Maybes its the Case and the Monitor!!!!! Get New ones Just to make sure!!!!`11111:hehe:
  14. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    Maybe it's given your machine an airbourne virus. :worried:
  15. SilverBullet
    SilverBullet Banned
    14 Oct 2002
    Were the sim city discs amde in IRAQ? arghhhhhhhhhh PC ANTRAX, infects the memorys chips slowly breaking down thhe circuits, Arghhhhhhhhhhhhhhh!!!11111111111
  16. Kevo
    9 Sep 2001
    :worried: maybe a monitor ;)
  17. SilverBullet
    SilverBullet Banned
    14 Oct 2002
    you can never be Sure !!!! :naughty: :naughty:
  18. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Ummm yea, no wonder. Didn't you think to troubleshoot before forking our for a new motherboard?
  19. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    Kevo, what cooler do you have? If it's an alpha you may want to try tightning it a bit. A re-application of thermal paste might be in order (unless you already did that).
    The only other thing it really could be is your video card. Tried reseating the heatsink on your gpu?
    edit: It could also be a bad power supply...:confused:
  20. Kevo
    9 Sep 2001
    Try reading my enitre post before even trying to flame me :rolleyes:
