Electronics Simple voltage converter, how?
Discussion in 'Modding' started by Twellmann, 8 May 2006.
  1. Twellmann
    Twellmann Carnivorous Homunculus
    5 Jan 2004
    I need a simple voltage converter circuit :D
    I need 1,2V out and I wan't to be able to hook it up to various batteries, 7,2 9 or 12 volts or the likes
    I'm not quite sure as to how much current I need out of this thing, but no more then 1 amp
    It will drive the glow plug on a Nitro RC car
    In short:
    2-20 Volts in
    1,2-1,3 volt out max 1000mA
    edit:
    I guess this could be used at Farnell #9493301
  2. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    Just get any fixed 1.2V voltage regulator, or use one like the one at farnell. Basically, any electronic company will sell something suitable, best if you can get a fixed 1.2V one. (Less parts)
  3. Starman97
    Starman97 What's a Dremel?
    17 Sep 2003
    You can use a linear regulator like the LM317T (see digikey)
    The only trick is that if you pull 1 Amp from the output,
    that means 1 Amp is pulled from the input power source.
    That's all fine, but 1 Amp at 1.2V is only 1.2 Watts,
    what happens to the (20v - 1.2V) * 1Amp = 18.8W ?
    It gets turned into heat in the regulator. So you're going to need a
    BIG heatsink if you run this for more than a minute or two.
    Even if you only run it for a few seconds, you still need a heatsink,
    that TO-220 package will burn out with 18W.
    Your other option is a switching power supply. These are more expensive,
    but far more efficient. The problem is, finding one that fits your
    requirements of 3-20V in and 1.2V @1A out. Not a big problem if
    you can design your own. Look up National Semiconductor's Simple Switch
    line, they have a web-based circuit designer. They also sell SimpleSwitch
    kits, not cheap, but they do what you want.
  4. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    The lm317 only goes down to 1.5 v
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Nominally 1.25V (+/-0.05V) which shouldn't hurt, and you could treat it as a fixed voltage regulator, no need for any resistors. Just connect the adjust pin straight to negative. Presumably this is only on for a short time, so whilst you need a decent heatsink it doesn't need to be enormous.
