SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. Teyber
    Teyber ******
    18 Mar 2007
    are you going to pay them or are you asking for hours of time from a skilled person for nothing? why not to it youself
  2. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    hey anybody got a sketchup of a lian li PC-G7?
  3. icutebluezone
    icutebluezone The meaning of life is to MOD
    6 Aug 2007
    Hi anyone got a sketchup of the Lian Li PC-V1000 ? I have looked on net and found 1 but is not even 1/2 made. and 1 got a finished model? Thanks
  4. jezmck
    jezmck Minimodder
    25 Sep 2003
  5. FrooP
    FrooP can I eat this?
    24 Oct 2007
    ooooooooooh shiny
    /me likes
  6. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    I'd really keep the 2 columns layout as it is now. While it looks fine at the memory category at the water cooling category one really would have to scroll.. a lot.
    But apart from that it really looks cool as it is now.
  7. b4i7
    b4i7 modding dreams into reality
    7 Apr 2007
    lookin great! one thing i noticed...the menus do not collapse back down after clicked open
  8. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    I agree - save the space, save everyone some scrolling trouble :clap:
  9. jezmck
    jezmck Minimodder
    25 Sep 2003
    I agree on the columns issue, but it's remarkably difficult to do anything about without resorting to a table for layout.
    If anyone can suggest a good way of doing it with CSS then please do let me know.
    Making the menus collapse back down will come in time.
  10. ComputerKing
    8 Sep 2006
    I will keep my eye on this thread but dam I will have to check 100 page , GRRRRRR
  11. Aterius Gmork
    25 Sep 2007
    What's the problem with good old collumns? <tr><td> Cheesecake.
  12. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    You could do it with a styled (block display) list, with the div's inside it set to 50% parent width i think
  13. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    the new version looks realy nice !
    I realy like the yellow color.
    Maybe you should use pages with like 10 items on each page instead of having more columns?
  14. jezmck
    jezmck Minimodder
    25 Sep 2003
    I'm not going to use tables, they're for tabular data, a list of items is not tabular data.
    50% width would seem the right way, but it seems more complex than that as the height can't easily be set.
    Pagination is also a possibility but I'm not convinced that there are enough items to warrant that in most categories.
  15. GuardianStorm
    26 Apr 2005
    I was bored at work:
    HTML:
    Code:
    <html>
    	<head>
    		<title>jQuery Testing</title>
    		<link rel="stylesheet" href="style.css" type="text/css" media="screen" />
    	</head>
    	<body>
    		<div id="itemContainer">
    			<ul id="itemList">
    				<li class="item"> ## Item code in here ## </li>
    			</ul>
    		</div>
    	</body>
    </html>
    CSS:
    Code:
    body {
    	margin: 0px;
    	padding: 0px;
    #itemContainer {
    	margin-left: auto;
    	margin-right: auto;
    	width: 80%;
    #itemList {
    	list-style: none;
    .item {
    	display: inline;
    	float:right;
    	width: 49%;
    	height: 150px;
    	border: 1px solid black;
    solves the height, width and all :) hope that helps :)
  16. jezmck
    jezmck Minimodder
    25 Sep 2003
    no, that's my point, I can't really use a set height, as that won't be enough for some items, and too much for others, and that in turn causes issue like this:
    i.e. the gaps as you can see top left and at the bottom.
    I can add code to add a break after every other item, but that adds a large gap after the first two items, and it's all getting too messy.
  17. GuardianStorm
    26 Apr 2005
    ahh i see what you mean. I will have a ponder while 'working' :)
  18. jezmck
    jezmck Minimodder
    25 Sep 2003
    it's a fiddly one.
  19. Deceiver
    Deceiver What's a Dremel?
    2 Aug 2008
    Hi, I am really new to this and been having a hard time on how to put holes for fan installation on the panel. Can anyone help give me a short tutorial or point me where I can learn how to do this?
    Thanks in advance!
  20. jezmck
    jezmck Minimodder
    25 Sep 2003
    Hi Deceiver, welcome to bit-tech.net!
    Cutting a hole should be fairly easy: use the circle tool to draw the hole on the surface, then use the push-pull tool to push through the panel, when you let go of the mouse it should cut the hole through the panel.
    Do go through the tutorials in SketchUp, they really do help.
