SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. k0rben
    k0rben I use my dremel as a toothbrush
    22 Jul 2010
    Hi Jez, i have a suggestion about moving either my scythe himuro model here
    http://scc.jezmckean.com/item/382
    to "high-cap storage" where this another scythe himuro model is
    http://scc.jezmckean.com/item/470
    or moving the second model to the "others" where my himuro currently is..
    Also, the second model should be "repaired" by author, some dimensions are bad.
    And you got PM with my himuro model version 2 download URL, it's slightly improved. Thumbnail on scc can stay the same.
  2. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    i tried to open the "Lian Li PC-V351 Micro ATX MB Tray" with SU 8 but i get an error message "unexpected file format" does it work for anyone else ?
  3. Cuzza
    Cuzza What's a Dremel?
    14 Apr 2010
    Thanks buddy. I should have some more coming in the next few days.
  4. Cuzza
    14 Apr 2010
    I can't d/l the file at all.... ?
    But I have also been getting that same error message for #464 "Gigabyte GA-P55M-UD2 uATX"
    Don't know what that's about.
  5. Ron-ski
    Ron-ski What's a Dremel?
    13 Jul 2009
  6. Dark~3nergy
    14 Jan 2007
    i tried to open the mb tray with su 7 earlier but it didn't work
  7. jezmck
    jezmck Minimodder
    25 Sep 2003
    Yeah sorry guys, having some problems with some files - I ran a script that was supposed to fetch all remotely hosted files but in some cases it's saved 404 messages and similar.
  8. Cuzza
    14 Apr 2010
    Just submitted:
  9. jezmck
    jezmck Minimodder
    25 Sep 2003
    Just added :)
  10. jezmck
    jezmck Minimodder
    25 Sep 2003
    Your file is now updated, the other item (382) is now hidden as there's no point having both.
  11. jezmck
    jezmck Minimodder
    25 Sep 2003
  12. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    CUZZA you doing all this in SU? really I'm have'n a fit here. GAZ...GAZ... Dude I'd like to see what you cuold do with solidworks or autocad! PFFFt! :D
  13. Cuzza
    14 Apr 2010
    Here's the pump I did today. Submitted it, mediafire is having issues jez so I used filedropper, hope that works.
  14. Cuzza
    14 Apr 2010
    Dunno, never used them!
  15. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    You know what I'd love to see... more Bitspower fittings. Compressions, elbows, snakes, etc.
    Also, more parts from EK. Their 280 rad, tube reservoirs, and their pumps.
  16. asura
    asura jack of all trades
    22 Apr 2009
    10-16mm BP comp accurate to .1mm (without the knurl or the thread, just took the outer measurement; can put it in if one where desperate for detail)
    Can only (properly) draw what I've got... working on a 172mm fan atm :thumb:
    *** Original image replaced with knurled***
  17. Cuzza
    14 Apr 2010
    I've been working on some more Koolance fittings craig, but no bitspower. The Koolance website has great dimensional drawings to use but I haven't found any for Bitspower. I don't have any parts to work from so without those technical drawings I would be trying to paint the Mona Lisa using a broom while blindfolded. Or some equally obscure metaphor.
  18. Ron-ski
    13 Jul 2009
    Yeah, put the knurl on at least, looks a bit plain otherwise.
    Anybody else find they keep trying to rotate pictures the Sketchup way?
  19. asura
    22 Apr 2009
    ***Original image replaced***
    Your wish is my command; you'll be wanting the threads on it next I suppose :rolleyes:
  20. craigbru
    28 Feb 2008
    Ah, so true. I've got a few fittings. Is there some way I can measure them that would be helpful to you?
