SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    Does anyone of you know of a working Sketchup exporter plugin that will export to either .obj or .3ds? I'm currently using this one, however I'd prefer one that will keep groups intact. This one is a nightmare for more complex models (as a mainboard).
  2. Ron-ski
    Ron-ski What's a Dremel?
    13 Jul 2009
    Can't say I'd ever noticed the donation button before, so I've sent a donation too, perhaps it'll start a trend. Keep up the good work :thumb:
  3. jezmck
    jezmck Minimodder
    25 Sep 2003
    Wow, Ron-ski, very generous, thank you! :clap::thumb:
  4. Cuzza
    Cuzza What's a Dremel?
    14 Apr 2010
    i'm down for that too
  5. Cuzza
    14 Apr 2010
  6. jezmck
    jezmck Minimodder
    25 Sep 2003
    Wow, another very generous donation, thanks Cuzza!
    Another excellent model added: http://scc.jezmckean.com/item/485
  7. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    Thanks cuzza ! :)
  8. Cuzza
    14 Apr 2010
    You're welcome. Now, no messing about, I want to see you churning out new motherboard models daily.:lol:
  9. Cuzza
    14 Apr 2010
    Any more requests? I need a new project.
    Also, Jez I made some minor updates to the LGA 1156
    please find the revised model here: http://www.mediafire.com/?y36v0k5h64uquc5
    and a revised thumbnail image here: http://imgur.com/RbaDF.png
    EDIT: Crap! this always happens. I had to make another change so I have re-upped and changed the links in this post. Hope you haven't downloaded yet.
    Dark~3nergy likes this.
  10. Spotswood
    Spotswood Custom PC case builder
    30 Jul 2007
    I'm almost too embarrassed to ask for these MNPCTech case feet , but yeah, I'm asking. :clap:
  11. Cuzza
    14 Apr 2010
    That can probably be done. Though some guesswork will be involved, so if you want accuracy you ain't going to get it. The overall dimensions are listed but everything else will be estimated.
    I can't see what is underneath them; ie the bottom surface of the foot. Guessing it looks like a black rubber disk a couple of mm thick??
  12. Spotswood
    30 Jul 2007
    [​IMG] :rock:
  13. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Sam, I can get exact dimensions of those feet if you need them. I've got a set in the basement.
  14. Cuzza
    14 Apr 2010
    Thanks Craig! That would be sweet.
    These are the dimensions I need:
    Also an estimation/description of the profile of those grooves would help. It is hard to tell from photos how deep and what shape they are.
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    I just had a look at the collection (awesome collection it is too :)) but just tried out a motherboard model from the collection & wow it's a bit laggy & was about 20 times the size of my entire design in megabytes, does anyone else get this or is it just my aging rig lol, my no thrills models lack detail but do the job right & none laggy so here's my question.
    Are these highly detailed models for use in final concepts only? or is my pc really that bad, I'm used to silky smooth rendering when designing with simple accurate size blocks I design myself.
  16. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Which model did you try?
  17. Waynio
    Waynio Relaxing
    20 Aug 2009
    tjay_Asus_rampage_extreme_x58
    MSI_Eclipse_Plus
    SAPPHIRE-HD-5870-Vapor-X
    ProlimatechMegahalems
    Loaded up on their own they're ok for me it's when I try putting them into my models, bugsplats seem to happen a lot when I paste the components into my models.
    Not to worry though I can get by without the models, just thought I'd give it a try :), I haven't recorded my cpu usage when trying it though, I'm guessing they choke my cpu lol, Q9650 @3.8ghz.
  18. asura
    asura jack of all trades
    22 Apr 2009
    rant warning
    SketchUp only utilises a single core, and it's a 32 bit application so it can only use 3gig of ram too. And they tell us over and over and over again, that multi core support and 64bit optimisation won't do us any good...
    So going to your bios and disabling 3 of your cores and overclocking your remaining core as far as you can push it will help a lot, but buying a dual xeon supermicro and a couple of quadro's will only help a little... Ridiculous? Damn straight!
    here endith the rant
  19. jezmck
    jezmck Minimodder
    25 Sep 2003
    rant acknowledged, but not by people that can do anything about it, go to the official blog or something...
  20. Cuzza
    14 Apr 2010
    I tried combining those three parts and pasting them into another file and it worked fine. A bit laggy, sure, but still quite workable, and I'm running an 12.1" ultraportable 1.6GHz Centrino with shitbox intel integrated graphics. You shouldn't have any issues with a Q9650!
