Skull case..
Discussion in 'Project Logs' started by GoTaLL, 1 Sep 2006.
  1. GoTaLL
    GoTaLL What's a Dremel?
    17 May 2005
    Hi again ..
    now im in the middle of the dreamhack winter rush to get stuff done..
    this is a case that been sponsored by Gtek.se
    its a berzerk case and perfect for lan events cause it got a handle ..
    well im in my Painting period of my life "again".
    its a black case .. i just lovem black..
    it looks really cool really.
    ok start of painting,, looks like my son would have made it.. ;) but i hopefully can make something out of it.. :p
    clearcoating.. and then some more..
    second time clearcoating .. starts to look sweet i think :)
  2. LuitvD
    LuitvD What's a Dremel?
    13 Aug 2006
    white on black is always nice :D
    Good luck on this one :thumb: looking good already
  3. cire9753
    cire9753 What's a Dremel?
    16 Aug 2006
    not really my thing but i can appreciate the skill it took
  4. GoTaLL
    17 May 2005
    kinda ruff still but will try detailing tomorrow..
  5. ZenX
    ZenX How are you gentlemen?
    5 Aug 2005
    Cool airbrushing skillzors :D
  6. ssR
    ssR Carbon God
    11 Aug 2006
    that skull looks pretty good :)
  7. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    X-cellent paint-fella:
    @ssR: pretty good, no-better than that..
  8. GoTaLL
    17 May 2005
    ok some more done this morning..
    like this it looked last night
    and this is how it looks now .. i dont know if i should do something more on the actuall skull tho but that we will see..
    well the whole case will have the same theme..
  9. GoTaLL
    17 May 2005
    ok now for the fun part of this project ,,
    Yesterday when i came hom i found my son sitting at my place holding the airbrush and was working on the case i had put up for work ...
    tis is the case with the skull i was a bit afraid what he had did but at a closer look it wasnt that bad .. it was the other way around it was sweet ..
    pic 3 is what my son did .. after that i keept going on that cause he didnt know what to do .. the real fun part is .. hes 10 years old.. never hold anm airbrush ..
    last night i rigged up and old airbrush set for him ..
  10. ssR
    ssR Carbon God
    11 Aug 2006
    i guess the airbrushing skills runs in his blood. skull looks MUCH better now, i wanna see more. keep it up!
  11. GoTaLL
    17 May 2005
    yeah but im impressed by the thing he did just on freehand and when i ask him normally when doing something for an event he says "ugly i can do better" and well ....
  12. Muon
    Muon What's a Dremel?
    1 Dec 2004
    we need pics of it now ^^
  13. GoTaLL
    17 May 2005
    the first pic is the 3 pic that is what he had done when i got home .. then i continued.. the first where its only white used..
  14. BlueBerryBoy
    BlueBerryBoy What's a Dremel?
    22 May 2006
    snyggt
    tanslation: nice
    pitty the holes for a fan are there
  15. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    Looks nice . Very nice.
  16. GoTaLL
    17 May 2005
    ok have continued some on it .. made somekind of "frame around the skull thing.
    bigger picture
    http://www.customengraver.se/bigimages/skullcase/DSC_7429.JPG
    there is a handle on the top and remade that partually with some paint so it matches up.
    bigger picture
    http://www.customengraver.se/bigimages/skullcase/DSC_7436.JPG
    and the front .. you wil have cd/dvd maybe a floppy or fan controller so i dont wanna put time to paint the things that will be removed so i just did a small skull at tha bottom of the front ..
    bigger picture
    http://www.customengraver.se/bigimages/skullcase/DSC_7445.JPG
    and something like this it looks now.
    just something small on the others ide and it will be done ..
  17. sunnyg
    sunnyg What's a Dremel?
    18 Aug 2006
    that looks really good. what airbrush and paint did you use?
  18. GoTaLL
    17 May 2005
    well im no pro on airbrushing but im trying, im using something that is called "vallejo" water based, and im using a evolution airbrush.
    if anyone remember the master "Boris Vallejo", if you dont try search for some of his art ..
  19. GoTaLL
    17 May 2005
    Morning .. well i did finnish this case .. and the end result om very pleased with .. and so is my son.. ;)
    check the final pics out..
    the skull side .. the dept really came thru..
    the front .. just to keep it up with the skull side .,
    the handle ..
    the other side .. there are 2 fan holes and a window so not mych space to play with so its just the same pattern on this side .. but it looks really cool ..
  20. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    wow that does look pretty good, you have teh 1337 airbrushing skilz
