Modding Sleeving Peripheral Cables? (Headset)
Discussion in 'Modding' started by mat0tam, 4 Jan 2012.
  1. mat0tam
    mat0tam Mr I Dont Know What I Want
    1 Sep 2011
    Thinking of sleeving my headset, and maybe Keyboard, Mic and Mouse
    Can I simply Cut, Sleeve, Solder + Heat shrink like standard wires?
    Would be useful to if people could point out if I can maybe do for one or more but not for say headset due to cable type :)
    Thanks
  2. bulldogjeff
    2 Mar 2010
    Most sleeving will open out far enough to go straight over the connectors, so no need to cut anything off and a lot of heat shrink is 4:1 so that should go on as well.
  3. mat0tam
    1 Sep 2011
    Hmm Ive got some 3mm sleeving for a 3mm cable, and my headpone jack is the issue as its like 12mm :(
  4. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Heatshrink is very cheap on ebay few quid buys you a yard so it's no great issue. Might want to get glue-lined heatshrink tubing though so that it stays in place once shrunk. The actual sleeving will be an issue though, I can't imagine anything smaller than ~5-6mm will expand over the headphone jack, that'll be a trickier one to work around unless you can chop the plug & resolder it ( maybe with a smaller 3.5mm jack connector + larger adaptor ).
  5. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    solder off jack (if it could be disassembled), sleeve what You want, solder jack back. don't forget to mark wires You un-soldering for proper re-soldering :)
    if jack couldn't be disassembled: before cutting away old jack find which wire goes to which ear (simply try any AA battery (-) to ground wire (+) for wire) and after sleeving solder appropriate jack.
    and You can always reverse channels in Your audiopanel :)
  6. mat0tam
    1 Sep 2011
    Awesome Thankyou :)
