Storage Slightly noobish question regarding transfering my OS across drives!
Discussion in 'Tech Support' started by coolicus, 19 Apr 2012.
  1. coolicus
    coolicus What's a Dremel?
    23 Apr 2011
    Hey all,
    Recently I fell victim to the tradgedy that is early SSD death (less than a year old) and the nice fellows at scan very kindly have sent me a new one. Unfortunately to get it working as my boot drive it seems that I would have to reinstall windows on it, along with all the drivers etc which is nothing if not a major hassle!
    I was wondering if you lovely people at bit tech could suggest an alternative way for me to transfer my OS across from my mechanical HDD to the SSD?
    Cheers!
    :D
  2. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    If you can download a copy of Hirens boot cd V.13 it includes Acronis home. Its as easy as picking source to target.
  3. murraynt
    murraynt Modder
    6 Jun 2009
    Or you can use drive XML to clone it over. Just make sure to enable trim and you set the sata mode to ACHI
  4. coolicus
    23 Apr 2011
    Nooby question again but how do I enable trim? Is it found in the BIOS?
  5. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    If the SSD supports TRIM it just "does" - you don't need to enable it. However, you need an OS that supports it too (Win 7 does, some newer versions of OSX do, and I think the later linux kernels do too)
  6. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    I always thought trim meant something else
  7. coolicus
    23 Apr 2011
    Why ye be trolling in the tech support section hippoz?
    Thank you and everyone else for their contributions though!
    Shirty likes this.
  8. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    Cloning gets my vote too, although I personally use CloneZilla. As long as the source partition(s) will fit on the target drive, you're pretty much ready to go.
    If your source drive is actually smaller than the SSD, you can always use something like GParted to non-destructively increase partition size later on; don't get rid of your original hard drive until you know this has worked correctly though, just in case :thumb:
  9. GeorgeK
    18 Sep 2010
    If you want to make extra sure that TRIM is enabled then open up a command prompt and type
    fsutil behavior query disabledeletenotify
    If it comes back with "DisableDeleteNotify = 0" then TRIM is on. :thumb:
