Storage Slot-loading Disk Drive
Discussion in 'Hardware' started by Moyo2k, 4 Aug 2009.
  1. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    You know them, the disk drives that "eat" your disk as you insert them, so how do I get one of those for my PC eh? I NEED ONE!!! NEEED... not need but want very very very badly
    Like this
  2. Krikkit
    21 Jan 2003
    It's called a slot-loading drive. Not many still around now, but yeah, they're awesome.
  3. LatinSpirit
    LatinSpirit Minimodder
    23 Apr 2009
  4. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Ty for quick response, that scan one is a bit pricey, nothing more than £35 please
  5. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    There is quite a few dvd slot drives on ebay for under 30 quid. Just search "slot loading".
  6. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    All slimline, how would I go about modding it to fit a normal 5.25" bay
  7. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Make a bracket for it i guess.
  8. simonw
    simonw What's a Dremel?
    24 Jun 2009
    I have a side question, is there a difference between slot loading or traditional tray loading drives on their reliability (mechanically speaking when loading/ejecting discs).
  9. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    Well there is a bit more can go wrong with slot loading...
    A bit more difficult to fix too.
  10. talladega
    talladega I'm Squidward
    18 Aug 2007
    I dont see how they would be too unreliable. Car CD players have been using slot load drive for years. The PS3 uses a slot load drive. Can't be too bad.
    They are really cool drives, but not very easy to find for low price.
  11. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Ive been looking for a slimline slotload bluray drive for a customer project, the only place i seem to find them are on ebay, all of them are from hong kong or similar and are about £80 which isnt too bad really.
    I have a full size slot loader at work, i managed to break it they really dont like dust :duh: its a pioneer dvd106s theres 1 HERE i doubt itll make alot of money tbh.
  12. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    So how do I fit a slimeline drive in a 5.25" Bay?
  13. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    May i suggest that you read the replies instead of spamming?
    ... or just buy the Plextor.
  14. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    and how do I go about doing that? Just buy a bezel?
    as for the kelp, the thread was dropping :D :D :D so I gave it a lift back to the top
  15. airchie
    airchie What's a Dremel?
    22 Mar 2005
    I don't see why slot-loaders would be any less reliable than tray drives?
    At least all their mechanisms are located inside the device itself unlike trays sticking out and getting knocked etc.
    I'm pretty sure you can buy adapters to take a laptop slot-loading drive in a 5 1/4" bay. :)
  16. Guest-16
    Guest-16 Guest
    Do that and ill start locking threads or deleting posts.
  17. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Slot loading drives have a major disadventage though. No cup holder.
    pimonserry likes this.
  18. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Just joking, I didn't realise the moderators lacked a sense of humour... :eyebrow:
  19. Guest-16
    Guest-16 Guest
    I've already deleted one :p:p
    We don't have humour.. we are ... not human :worried::cooldude:
  20. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    eh em.... ok so how do I go about making a slimeline bracket
