Small Form Factor Small form factor cases
Discussion in 'Hardware' started by bowmore, 26 May 2005.
  1. bowmore
    bowmore What's a Dremel?
    25 Jul 2004
    Hello, I was basically just wondering if they sell the shuttle type cases just on there own, as in no components maybe just the PSU? ive checked Ebuyer and a few other places but cant seem to find them.
    Thanks
  2. Hiren
    Hiren mind control Moderator
    15 May 2002
    No to the cases unless you get one off e-bay. The PSU's you can buy seperate, check the sticky for a list of places that sell.
  3. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    "Shuttle type cases" are a proprietary for factor that do no support other motherboards. If you want a Smallish case of similar configuration and dimensions that supports Micro-ATX motherboards look for the Antec Aria. If you want an ITX case there are a handful of options.
    The only UK sources I'm personally familiar with are http://www.ultim8pc.co.uk and http://www.mini-itx.com
  4. Kickn
    Kickn What's a Dremel?
    7 Oct 2003
  5. bowmore
    25 Jul 2004
    Thanks for info (K) i just wanted figured "ive got a mobo lets use it" but i might be making a pc for my sister because she's not allowed on mine or my mums cause she mucks them up because she thinks she knows what shes doing " i got a C in IT in my gcse's" is her excuse. and yet she thought our router was a base control box for the speakers :|. so i'll probably just by a new one anyway.
