Cases Small HTPC case suggestions.
Discussion in 'Hardware' started by Kronos, 15 Sep 2011.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    I am looking for suggestions for a small and cheapish m-atx case, I initially was going to get the Fractal Design Core 1000 mATX Case but have decided that I want something smaller. It will be taking this mobo http://www.scan.co.uk/products/asus...55-ddr3-sata-ii-3gb-s-pcie-20-(x16)-micro-atx and I would like to install a reasonable sized GPU. At the moment I have an 8400GS lying about but will probably upgrade in the future if its necessary. The PC will mainly be used for streaming films videos and music and will sit as unobtrusively near the TV.
    I know there are some tasty LianLi and was wondering if this will suite my needs? http://www.scan.co.uk/products/lian...ce=google+shopping&utm_medium=google+shopping It is probably more than I initially wanted to spend seeing as the fractal is around £30.
    So any other suggestions folks.
  2. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Hmmm you can't use that Lian Li. Its mini-itx mate. I'm getting the Fractal case for the same purpose. Its not that big lol!
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    Thanks for pointing that out.
  4. chris66
    chris66 Minimodder
    10 Jan 2011
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
  6. Nealieboyee
    14 Aug 2009
    A bit higher than £30, but how about THIS one?
    Or THIS one for £33
    HERE is it on Play.com with a customer's review.
    Apparently it takes a matx psu, so it might not be suitable.
