SMP client problem
Discussion in 'bit-tech Folding Team' started by steeli, 20 May 2009.
  1. steeli
    steeli CPC Ronin
    2 May 2009
    Have set up the SMP client per the latest CPC mag, but it doesn't seem to be doing anything.
    It's starting up and appears to make a start but the only cpu time being used is that of the gpu client.
    Have I missed anything? I think i've set the right options for not using affinity, on vista x64.
    [folding]un=steeli&t=35947[/folding]
  2. steeli
    steeli CPC Ronin
    2 May 2009
    never mind it's started. slowing the gpu client down now!
  3. Unicorn
    25 Jul 2006
    Are you using the VMware SMP client?
    Don't forget that you have to set the VMware client's CPU priority to low in task manager to make sure that the GPU client still gets it's share of the CPU's time.
  4. saspro
    saspro IT monkey
    23 Apr 2009
    I run 2x VMWARE SMP's and 1 xGPU on a QX9650 @ 4GHz no problem.
    As Uni said set the priorities.
    The guide's in the mag are good (although I didn't write the SMP one, only edited it)
  5. steeli
    steeli CPC Ronin
    2 May 2009
    I changed the priority to low after restarting with -config switch.
    All folding along happilly now. Only using one SMP client, just set as per the mag bar changing the priority to low.
  6. Unicorn
    25 Jul 2006
    Glad to hear it! :)
