Photos So I put together a Ghetto lightbox
Discussion in 'Photography, Art & Design' started by yodasarmpit, 8 Feb 2008.
  1. yodasarmpit
    yodasarmpit Modder
    27 May 2002
  2. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    sweeet, melikes.
  3. Whelan_999
    Whelan_999 What's a Dremel?
    4 Jul 2005
    Nice, saved you some $ so who cares how ghetto it is.
    -aaron
  4. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    I'm making the same damn thing at the moment :D
    We'll have to share results! ;)
  5. supermonkey
    supermonkey Deal with it
    14 Apr 2004
    Unless Dorothy pulls back the curtain, nobody will ever know that the wizard is just an old coot. If it does the job, that's all that counts.
    I love it!
    -monkey
  6. Shadowed_fury
    21 Nov 2003
    If anyone is interested, although it is easier than walking, the guide was from Strobist! :)
  7. Firehed
    15 Feb 2004
    They're nice to have, aren't they? I made something similar a while back except mine was big enough to hold a big PC case with basically the same method. Now I just fire through a couple umbrellas on either side for the same effect, with a paper backdrop (much more compact when not in use).
  8. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    Are you using the hot light in conjunction with an on camera flash by any chance? If so, try taking it with out the flash. There is a certian flatness to the image that comes from flash straight on, and I see 2 highlights (in red) that I think are very distracting from what could be a good shot. Also, there are shadows (in blue), that the lightbox are intended to remove by diffusion.
    If you look at the first setup shot, then you see the flatness and the highlights, but the second setup shot has a great soft light that shows off the curves of the lenses with shadows. The final shot, while having some of the shadows that the define the lenses, has just enough flash to add a splash of garishness to it. I hope I am making my point clear. If you need a second light (and in a box like that you might not) I would try a second hot light on the right but further back to lower it's power, or the flash-if you can get it off camera.
  9. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Thanks JJ, great points.
  10. Vers
    Vers ...
    23 Oct 2007
    I agree with johnny, only to add that you can add two front barn doors (white) to bounce some light onto the front/face of the object you are shooting. It will help significantly, and perhaps you wont have to utilize a secondary light source.
  11. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Had another play around, this time only using the hot light to the side.
  12. Fod
    26 Aug 2004
    da, is better. i like the side shadowing.
  13. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    Amazing how the light brings out those little tiny microscopic dust particles. :D
    And great light box, considering its home made. :)
  14. Jumeira_Johnny
    13 Nov 2004
    The 2 new shots are much better, IMO. If I had to give constructive feed back, it would be that for the USB stick, I would have gone with a gray background. The silver/white of the USB gets lost a bit on the lanyard. And if you really wanted to make it pop, maybe a little light painting on the OCZ logo. Since that is usually the focus of product photography. Which I realize is not what you are trying to do here. Otherwise, an overall good shot with a high key look.
  15. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    Forgive my n00bishness, but what is lightbox used for? The pictures are really nice btw. Yoda, what camera have you got?
  16. Fod
    26 Aug 2004
    a lightbox is for getting pictures like that :p
    they're used in product photography to make the item look sexier.
  17. OleJ
    OleJ Me!
    1 Jul 2007
    W/O flash is a lot better. Congrats on the new lightbox :)
  18. jeff127
    jeff127 What's a Dremel?
    21 Jul 2006
    That last one is excellent. Good work. :)
    Jeff.
