Graphics So my GPU is fudged then?
Discussion in 'Tech Support' started by yakyb, 18 Mar 2010.
  1. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    anyone seen this before
    this GPU has never been oc'ed only used 2 times a week and all of a sudden its started to be ****ed
    its an 512MB XFX 9800GTX XT 720Mhz bought july 2008 should i just cut my losses and get a 5850 / 5770
  2. mrbungle
    20 Sep 2004
    xfx have a decent warranty i think?
    check it out
  3. yakyb
    10 Oct 2006
    does installing a third party cooler effect the warranty
  4. Domestic_ginger
    Domestic_ginger What's a Dremel?
    16 Mar 2010
    Most probably.
    Just out of interest is your bios showing atifacting? Never seen a screenie like that before.
    You're not using the dodgy latest drivers by any chance?
  5. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Yes. It voids your warranty.
  6. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    One of the primary killers of graphics cards is heat. Did you install a third party cooler yourself?
    (The others are right BTW, if you did your warranty is void.)
  7. yakyb
    10 Oct 2006
    okay bugger
    thanks guys
    and yes the post screen does start to show atifacting not sure about the bios page yet
    yes did install the third party cooler my self but its been running like that for a year at least now
    oh well time to splash some cash
  8. Domestic_ginger
    16 Mar 2010
    Search the web for similar issues; seen similarish issues. You may be able to bake the card back if it is only microfracture.
    If you can't face it you can always sell your faulty card on ebay; there is a quite a market for artifacting cards. I've been looking for a project (and been dying to try the oven bake) but have not been able to find a card that would make it worthwhile; hence the ebay interest. Was hoping for a g200!
  9. Teelzebub
    27 Nov 2009
    XFX warranty in the UK 2 years I believe and not modder friendly , USA double life time and you can do any thing you like to it.
  10. yakyb
    10 Oct 2006
    funnily enough i have just tried baking it just letting it cool down before trying it in my machine
    if it doesnt work i'll get myself a 5770
  11. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    hehe you baked it.. hope it works
  12. yakyb
    10 Oct 2006
    **** me its worked
    seems to be running ok
    odd little thing here abd there but not like above
    baked at 250 for 30 mins let cool for a couple of hours then refit it and it seems okay will run a game tomorrow as it is late now but i seem to at the very least have a half working card again
  13. Domestic_ginger
    16 Mar 2010
    It should be 200for 10 mins! Hope nothing fell off (components!)
    gratz if its all ok!
