PSU ...so, my pc won't turn on.
Discussion in 'Hardware' started by RedFlames, 24 Mar 2019.
  1. RedFlames
    23 Apr 2009
    Well, my venerable 10yr old PSU has given the bucket a swift old kick.
    So recommendations on a replacement that is -
    cheap
    at least semi-modular [captive 24-pin/EPS 8-pin is fine]
    not made of depleted chinesium and/or 'splodium
  2. adidan
    25 Mar 2009
  3. David
    7 Apr 2009
    Is your GPU bus powered? Because I have a modular 750W PSU with no PCI-E cables.
    Yours for postage, if it'll get you up and running.
    Vault-Tec, RedFlames and adidan like this.
  4. adidan
    25 Mar 2009
    If it's a Be Quiet I have cables left over when mine died if they're compatible.
  5. RedFlames
    23 Apr 2009
    ...what gpu? :p
    and thanks but if there's one thing I have to buy new, it's a PSU.
  6. David
    7 Apr 2009
    No it's a Novatech Power Station 750W Black edition.
    It's 80 plus certified and does that fan over-run thing for a couple of minutes after you shutdown.
    If anyone know who manufactures Novatech's PSUs, maybe it's possible to get spare cables for it.
  7. David
    7 Apr 2009
    Ninja post!
    No worries, mate.
    RedFlames likes this.
  8. RedFlames
    23 Apr 2009
    Having a PSU let go and taking the entire PC with it will do that to you. Tbh there were a couple times I thought this one had done it [and i'm not sure it didn't kill my last GPU],
  9. RedFlames
    23 Apr 2009
    I'm well aware of that, but my PC doesn't have a dGPU atm, it's running off the CPU's IGP. hence 'what gpu?'.
  10. David
    7 Apr 2009
    This one was powering a 7700K and 1080ti but the pcie cables got misplaced/accidentally thrown out.
    I fully understand the caution though :)
  11. RedFlames
    23 Apr 2009
    You can't un-smell that blown psu smell...
  12. adidan
    25 Mar 2009
    QFT
    Thankfully my PSU took one for the team.
    Stank to buggery though.
  13. Vault-Tec
    30 Aug 2015
    Great PSU. It was the same one OCZ used to use for their 750w Fatal1ty range. There should be a JonnyGuru review kicking around somewhere, as I used it when I bought my OCZ.
  14. Anfield
    Anfield Multimodder
    15 Jan 2010
    Smells like smouldering HDD PCB, certain to lift the mood at any house party:thumb:
