Socket AM2 And the Phenom.
Discussion in 'Hardware' started by coniferous, 6 Oct 2007.
  1. coniferous
    coniferous What's a Rotary Power Tool?
    9 Jun 2007
    From what I've seen an researched, the new AMD phenom will fit into socket AM2. I'm planning on buying a computer soon and wondering if this mobo will support the phenom when it comes out.
    I've seen varying reports about some manufacturers releasing a firmware update so that the older mobos will be able to support the new processors, but I'm not sure.
    Will this work? Should i wait?
    thanks in advance :)
  2. wyx087
    15 Aug 2007
    i thought you need AM2+ to be able to use phenoms
  3. capnPedro
    11 Apr 2007
    AM2+ processors will work in AM2 boards, but you lose out on some special voltage controls.
  4. coniferous
    9 Jun 2007
    So, i'm getting the feeling i won't loose out on any speed then, which is what i was really worried about.
  5. atanum141
    22 Jul 2004
    No you wont, as said the only thing lost is the voltage regulation which the new AM2+ cpu's can regulate each separate cores voltage and core speeds.
  6. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    You also lose out on the AM2+ 2.0Ghz Hyper-Transport speeds, and are limited by the 1.0Ghz of AM2. I don't know if this will have any effect on performance however.
  7. coniferous
    9 Jun 2007
    Great! Thanks for all the help guys, i just bought the computer :)
